E55 runs 10.39 tonight at Palm Beach International Raceway 😱😱
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
How much n20 ?
Hulk, first time at the race track, ran 3x and managed a 11.12 with a 1.7x 60 foot at 125 on one pass and spun out of the hole the other 2x. Also a full weight car with 18 inch DR, thanks JR.
A Weistec C63 coupe ran 10.7x @ 130, it was a great night for Merc fans.
305e55 pass
305e55 pass
Thanks to all of you for the props
I don't know how to do multiple quotes if not I would thank you all individually..
Urbanworm I did go up a little bit,the cold weather helped as well.. The car is full weight just CLK wheels with M/T Drags..
. Great job
