Dr Chill what's up with your spare....
Old Nov 28, 2003 | 04:25 AM
norb's Avatar
2009 C63 AMG
Can you give details on the spare tire you're carrying? Is it a rear wheel? Is it a true spare?
Old Nov 28, 2003 | 08:38 PM
Dr Chill's Avatar
Porcelain Bus
Currently I'm carrying an 18 x 8 front AMG 5 spoke wheel that is part of a set I got for my mother in law's E500 with a worn Continental Sport Contact. It takes up most of the trunk but beats being stranded and should work in the rear if needed
Old Nov 28, 2003 | 10:12 PM
MgnFicnT's Avatar
'02 C32 AMG
Should work? so your not sure if you going to be stranded or not?
Old Nov 29, 2003 | 01:53 AM
AMGB's Avatar
Dr. Chill,
Not knowing that much about tires, will that fit on both the front and back and be able to clear the massive brakes?
Also, why don't you put it below the truck. The guy at the dealership told me you can take out the lining and there should be enough room for an 18 inch tire to fit.
amgB
Old Nov 29, 2003 | 09:18 PM
Dr Chill's Avatar
Porcelain Bus
The wheel is the same as the ones offered as a no cost option when ordering an E55. It will fit identically to the twin spoke wheel in front. In the rear, the clearance from strut housing to the inside of the wheel will be 22mm MORE, the outside edge of the wheel will RETRACT in towards the body by 4mm.
Old Nov 29, 2003 | 10:30 PM
pocholin's Avatar
Volvo V90 CC
You know your car
Old Nov 30, 2003 | 04:29 AM
AMGB's Avatar
Dr. Chill,
So does that mean I should order the front wheel for my spare? Do you know how much that is going to cost. I will be going to Las Vegas in January and don't want to drive in the desert without a spare.
Thanks.
amgB
Old Nov 30, 2003 | 02:44 PM
Blocktrader's Avatar
2003 E55,2005 Ferrari F430 Spider, 2005 Corvette 427 TT, 2005 Range Rover
The front definitely fits on the back and vice versa. I swapped them to see if I could get the backs on the front. There were no clearance issues with either.
