Grinding/vibration when accelerating
Old Apr 7, 2014 | 10:04 AM
dvdt's Avatar
07 Ducati S4R & 04 e55
Hi All
Car developed a strange issue recently. If i accelerate slowly it feels normal, but if i give it a bit more i can actually feel a grinding feeling through the floorboard!
I replaced the motor and trans mounts about 5 months ago, and the carrier bearing about a month ago.
Could it be a failing u-joint? Any ideas welcome!
Old Apr 7, 2014 | 11:46 AM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
Check the driver side down pipe clearance (right at the curve). It may touch the floor when you have too much torque or your engine mount goes bad.
GL
Old Apr 7, 2014 | 12:26 PM
novae500's Avatar
W211
i have this as well when i stomp on the gas...Thought it was the headers rubbing but not, bad wheel bearing, not. replaced by leaking power steering pump last week and seemed to go away.
Old Apr 7, 2014 | 01:46 PM
vioilio's Avatar
2003 E55 AMG
Originally Posted by dvdt
Hi All
Do you have long tube headers?
Old Apr 7, 2014 | 02:29 PM
dvdt's Avatar
Nope, bone stock.
Old Apr 7, 2014 | 03:24 PM
James M's Avatar
03 E55 AMG
Does this problem happen in 1st gear only on hard take-off or all the gears?
Old Apr 7, 2014 | 05:47 PM
dvdt's Avatar
Any gear if you give it enough throttle!
Old Apr 7, 2014 | 05:49 PM
dvdt's Avatar
I'm thinking there is a small possibility that one of the nuts came off of the top of the motor mount, and now the motor is pitching over when under load.
I torqued those things as best i could but damn was it hard to get good leverage up there!
Old Apr 7, 2014 | 10:00 PM
mobhouse's Avatar
Mercedes E55
This is happening to me now too! I'm figuring its a mount because if i let off after doing so and it shifts up, i get a loud slam.
Old Aug 18, 2014 | 06:52 PM
kalyons56's Avatar
cls 55 amg
solution
Hello,
Has any one found the culprit for this issue?
I just picked up the cls55 2 nights ago. The test drive was perfect and I was very conservative during the test drive after I signed all the papers and left I smashed on the gas and got the same vibrations under the floor board described. Anyone know what this is?
Any help would be appreciated!
Old Aug 18, 2014 | 07:23 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Originally Posted by kalyons56
Hello,
Miles? Check wheel bearings, and also check the rubber flex things on either end of the drive line as they as super common. Driveline shouldn't be going bad but it won't hurt to check the center coupler piece thingy in the middle of the drive line.
Old Aug 18, 2014 | 07:42 PM
kalyons56's Avatar
cls 55 amg
Thanks for your response. It has 73k miles.
Will definitely have your recommendations looked into
Old Aug 19, 2014 | 09:59 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Check the motor mount bolts both sides, top & bottom. I had this problem when the dealer forgot to reinstall them after working on my car.
These bolts seem fairly week also. I snapped one by hand during an install not too long ago. So, maybe it broke.
The lower bolt part number is 2209902201
Old Aug 19, 2014 | 10:02 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
can you check the differential
Old Aug 19, 2014 | 11:06 AM
vioilio's Avatar
2003 E55 AMG
What exactly in the differential?
Old Aug 19, 2014 | 11:12 AM
shardul's Avatar
rear diff
Old Aug 19, 2014 | 12:08 PM
vioilio's Avatar
2003 E55 AMG
rear diff
what exactly is one suppose to look for in the rear differential? A friend of mine does have this exact same issue
Old Aug 19, 2014 | 03:19 PM
biggking's Avatar
Motor mounts are way different when they are bad. I had issues where the entire car lurched at a stop or take off. I also had some vibrations due to a bad transmission mount (20 min to replace on a lift) and also I changed my end rubber pieces for the drive line (they were cracked). I honestly think it was the transmission mount, I have actually replaced one earlier today and the car had major vibrations and it sounded like a diesel on take off. After we replaced the mount ($60 from MBZ i think) the noise and vibration went away. Upon initial inspection of the car we could not tell that the rear transmission mount was bad. Once we removed it, the play was insane.
Old Aug 19, 2014 | 03:26 PM
shardul's Avatar
also check drive shaft flex plates
Old Aug 19, 2014 | 03:35 PM
biggking's Avatar
Totally forgot what they were called. Thanks for that.
Old Aug 19, 2014 | 03:54 PM
shardul's Avatar
guibo for BMW folks
Old Aug 19, 2014 | 04:30 PM
biggking's Avatar
guibo for BMW folks
Yea, more like my sub frame might fall off first though
Old Aug 19, 2014 | 04:32 PM
shardul's Avatar
sometimes if the cats are blown out you will get a vibration on the floor board at WOT
Old Aug 19, 2014 | 05:31 PM
BagMan's Avatar
I had a missing motor mount bolt and had the exact same symptoms described by the OP. Car felt normal until I floored it, then there was a vibration under the driver's footwell.
It took me a while to figure it out, but it's a easily identified visually.
Old Aug 19, 2014 | 08:31 PM
mobhouse's Avatar
Mercedes E55
Had this same issue around 77k miles and found out it was my motor mounts/ transmission mounts. drives perfect after replacing them
