best method to remove oil pan
Old Apr 22, 2014 | 10:04 PM
nowak32's Avatar
2005 E55
I have found I have a small leak at my oil pan. I know this is not a quick fix. Reading through the archives I cant find a lot of information on this procedure. what is the simplest method to get access to the pan? engine removal? sub frame drop? are there any tips on doing this as easy as possible? also. is there a pan gasket? or just use RTV?
thx
Old Apr 22, 2014 | 10:35 PM
amg_w211's Avatar
2014 E63 AMG S, 4Runner
Oil pan factory instructions
I've never done the repair, but for what it's worth, here's some factory instructions on the oil pan. As you have a W211, and 113.990 engine, only follow each step that applies. If it states for a different model, you can skip the step.
There's the main oil pan (I'm assuming that's what's leaking in yours) and the secondary pan (sump pump).
Looks like a huge PITA. Good luck.
File Type: pdf
Old Apr 22, 2014 | 10:53 PM
amg_w211's Avatar
And per factory instructions, it appears to be a type of Permatex black RTV. I've attached instructions for the lower oil pan and the upper oil pan. Probably the lower is all that you need to follow.
Again, if a service step has no model listed, you need to follow it. If a step lists your model, you need to follow it. If a step lists other models, but not your model, then you can skip. The WIS instructions aren't the most clear, but that should help you figure out what you need to do or can skip.
Old Apr 23, 2014 | 09:16 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
The E55 has two piece pan set up, so it depends on what part of the pan is leaking (upper or lower). If it is the lower pan, then you should be able to lift the engine up with and engine hoist and remove the lower pan. The pans do not have a gasket, just sealant and this is time consuming part. I use only MB sealant, as the job takes to long to mess around with other sealants. You also need a good quality spray on gasket remover and all old sealant material must be removed and surface cleaned! If you get one drop of oil on the sealant surface, you will have a leak again.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Apr 23, 2014 | 09:41 AM
3BNick's Avatar
2006 E55
I had to lower my subframe when I pulled both pans to replace my oil pump. I agree about using the mb sealant and be sure the mating surfaces are spotless and oil free for best results.
Old Jun 29, 2014 | 02:15 AM
OCAMG55's Avatar
2005 SL55, 2010 E550
I think my car has the same problem. HMy Machanic told me he will charge me $2300 for the job. He said the oil leak is from main oil pan. Or something like that. From v belt section . The engine needs to be removed from the car . But I have e63 . I am not sure if it is the same thing . Does anybody know what should be the right price for this type job . Do we really have to remove the engine? To be frankly, I have never heard of any car needs to remove the whole engine to stop the oil leak. Any input will be helpful to me. Thanks
Old Jun 29, 2014 | 08:57 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I just did this last night, I used screwdrivers as wedges and very carefully worked my way around until it popped loose. (sub frame out) Don't force it, that pan looks expensive.
Don't be afraid to sharpen a $10 screwdriver. Had to loosen the transmission line clamps for one tab in the way.
I plan on resealing with Yamabond4. It won't leak and it will be removable again. I'm not impressed with MB sealer since it didn't work from the factory, especially on my valve cover breathers. Yamabond4 will survive heat, vibration, gasoline, and pressure all at once.(two stroke dirt bike engines)
Old Jun 29, 2014 | 12:07 PM
draggbody's Avatar
2005 e55
the only thing i have to add is my opinion on sealant... i use Ford Powerstroke grey engine sealant... around $15 at the dealer for a half sized caulking tube... it is BADASS... i even have some mercedes technician friends of mine using it...
Old Jun 29, 2014 | 03:59 PM
OCAMG55's Avatar
Wish some of you can post the DIY section with pictures. any body in Orange county area. i can hire somebody did this for me.
Old Jun 30, 2014 | 03:13 PM
OCAMG55's Avatar
Do you have the instruction how to remove E63 oil pan? Thanks
Old Jun 30, 2014 | 03:44 PM
OCAMG55's Avatar
oil leak picture
I have uploaded lots of picture. this is the oil leak from from oil pan. can anybody help me to identify if this is the same leak what you guys talking about? Thanks> it looks like the main oil leak is from part number. A1560140902. Also the black color oil pan close to transmission either.
Attached Thumbnails best method to remove oil pan-1-1-.jpg   best method to remove oil pan-1-2-.jpg   best method to remove oil pan-1-4-.jpg   best method to remove oil pan-1-5-.jpg
Old Jun 30, 2014 | 04:07 PM
OCAMG55's Avatar
Here is the pics of back oil pan ( black color ) right next to transmission.
Attached Thumbnails best method to remove oil pan-2-1-.jpg   best method to remove oil pan-2-2-.jpg   best method to remove oil pan-2-3-.jpg   best method to remove oil pan-2-4-.jpg
Old Jun 30, 2014 | 11:56 PM
OCAMG55's Avatar
oil leak
nobody can help on this?? I have been waitting for whole day and looking for hear from some members.
Old Jul 1, 2014 | 05:53 AM
Not sure what you are waiting for, both your pans leak. Your options are fix them or don't fix them. It doesn't match mine because mine didn't leak, I pulled it off purely out of curiosity, and to see if I could fix the chain. If you have a specific question about how to fix it I'll be glad to help if I can.
Old Jul 1, 2014 | 06:48 AM
MindBend's Avatar
'05 E55
It's a pain:reward ratio. If the pain (or cost) of fixing it exceeds the reward of the knowing it's fixed, leave it alone. It's pretty easy to put a little oil in the filler once in a while. (if it's even that bad).
Seems like a good project for a rainy weekend. (or drink beer and forget it).
Old Jul 1, 2014 | 10:43 AM
OCAMG55's Avatar
I am definitely plan to fix it. However don't know how to work on this car. Just order the service manual . Don't know when is it going to arrival. I am also think about to hire a Machanic to do this depends on price.do you have any idea how much will this be charged in Indy shop?
Old Jul 1, 2014 | 10:47 AM
OCAMG55's Avatar
The oil leak is actually pretty bad. It drip to the floor of my garage. SoCal almost do not rain in this season..........a list is been line up for me to do. Front brake pad and rotor. Engine and transmission mount . Engine oil. Two front tire needs be replaced . All parts are ready. I just keeping busy and don't have time to do it.
Old Jul 1, 2014 | 11:37 AM
kponti's Avatar
E63
This does not look like a take a day or two on a weekend and do it. Drive to work Monday. If you are as busy as you claim, you may have to plan on not driving it for a week or two and work on it as you have time.
