Advice needed - uneven tire wear
Old May 3, 2014 | 09:29 PM
jaxn5's Avatar
E55K
I normally drive the car in Sport1 (sometimes Sport2), and I know this causes some negative camber.
Attached pictures are of the front tires; the insides are very worn.
Is the negative camber so aggressive that it causes such uneven tire wear? The inside of my tire is gone. Is it worth having the tires unmounted and rotated? Swapping the fronts. Or should I just buy new tires?
Attached Thumbnails Advice needed - uneven tire wear-20140503_173952.jpg   Advice needed - uneven tire wear-20140503_174133.jpg
Old May 3, 2014 | 10:28 PM
Toadster's Avatar
2005 E55 AMG
very common on these cars, my last set lasted me 18k miles (which is FOREVER to some guys) - went with Michelins this time to get a little back on the next round
Old May 3, 2014 | 10:48 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
First pic looks like the wearbars are close to the tread depth, second pic shows a whack of lead on the rim, like 2 1/4 ounces, IMO its time to replace, if you ever get caught in a downpour, hydroplaning would be expected. Not a good idea to cheap out on brakes or tires.
Old May 4, 2014 | 12:13 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
I swear we need a sticky about this. It gets asked at least 5 times a week.
Old May 4, 2014 | 07:40 AM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
Inspect all of your suspension bushings, ball joints, and tie rods. If there are any failing items then replace them. Install new tires, and have an alignment performed on the vehicle.
Old May 4, 2014 | 08:18 AM
macko's Avatar
e55 2005
what was the tire pressure?
Old May 4, 2014 | 11:25 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I just picked up a new set of Pilot Sport AS/3s, and I noticed they have a 45k mile warranty. Have you had any luck with getting a new set that way?
Old May 4, 2014 | 11:43 AM
Shadow5501's Avatar
Car free at the moment
Michelin cuts the warranty in half if you have staggered sizes, so it's actually 22.5K om the AS3. You likely won't have any trouble reaching that mileage.
Old May 4, 2014 | 11:54 AM
moosejaw's Avatar
none
1. all german rear wheel drive cars have uneven tire wear due to factory alignment settings. Even the most basic 3 series has this problem
2. The torque from our cars cause a squatting issue in the rear where the suspension will compress under full throttle so hard launches do contribute to this as well.
3. Get an alignment and try to get the crash bolts for the front which can help with up 1 degree
4. Drive around in sport II mode and i believe comfort mode.
Hard Launches will cause bad tire wear in the rear. I hardly launch my car and ive gone about 20K miles on my Hankooks
Old May 4, 2014 | 01:47 PM
Toadster's Avatar
2005 E55 AMG
you won't get a new set, since our wheels are staggered setup you can't rotate so they 1/2 the warranty - so your 45k is actually 22.5k
they pro-rate the warranty - so in my case with 18k miles, I'd get about 20% back - better than nothing
plus Michellin has some nice towing/roadside assistance for free
Old May 4, 2014 | 02:19 PM
jaxn5's Avatar
E55K
Thanks for the helpful repsonses guys!
The rears show some uneven wear but looks normal for negative camber. No where near as bad as the front.
I'll get the suspension checked, replace the tires and get an alignment.
Fronts at 37-38 psi.
Old May 4, 2014 | 11:39 PM
HeissRod's Avatar
No one has asked yet if this person is lowered?
Old May 5, 2014 | 01:11 AM
jaxn5's Avatar
E55K
haha oops forgot to mention stock height
Old May 5, 2014 | 05:59 PM
baldmike73's Avatar
ill have to check this when my car goes in tomorrow for new tires - opted to try the Bridgestone RE-970AS -
if i get some $$ back may need to stick with the PSS
Old Feb 19, 2018 | 06:36 PM
95viper's Avatar
2007 cls550
Google Mercedes OEM front camber bolts and install them.
Old Feb 19, 2018 | 08:48 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
Or you can do what I do, buy these bad dogs for dirt cheap and shred them all day long haha.
https://www.walmart.com/ip/Antares-I...9-96W/55692748
Old Feb 20, 2018 | 08:57 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I was told by those in the know, that no matter what suspension setting that you select either it be C, S, S+, it has no relevance on the ride height of the car. The suspensions settings just controls the dampening /rebound of the shocks.
So that has nothing to do with your uneven tire wear, due to negative or positive camber.
Old Feb 20, 2018 | 09:38 AM
95viper's Avatar
2007 cls550
This is not true if talking about airmatic cars. The settings definitely lower the car and impact camber.
Old Feb 20, 2018 | 10:58 AM
Yuille36's Avatar
Yes, I'm talking about the airmatic. I've owned my 07 E63 for 10 years, and I haven't noticed a difference in ride height in either of the settings. The suspension settings correspond to the stiffness in the shocks, and aren't related to ride height.
I ask this same question years ago in the AMG Private Lounge, and was told the same thing, it's stiffness not ride height.
Old Feb 20, 2018 | 11:15 AM
95viper's Avatar
2007 cls550
Ask again if you don’t mind because I researched this a few years ago and there are dozens of articles out there disputing that. You aren’t noticing it because it adjusts when the car starts moving and it adjusts to different levels based on what setting you are in.
Plus simply think about our airmatic’s and springs themselves. I also have a 07 but a CLS550. The airbag doesn’t have a way to stiffen. Are you suggesting that the compressor loads up more air but keeps ride height consistent?
What makes sense is that the airbag drops 15mm and this stiffens the springs as they compress. Right?
Please ask as I am totally curious to hear a technical reason on how it would work otherwise. Thanks!
Old Feb 20, 2018 | 12:27 PM
Yuille36's Avatar
I will reach out to a good friend of mind that happens to be a AMG Tech and Shop Foreman at a local MB Dealership. Awaiting his response.
Old Feb 20, 2018 | 12:59 PM
Yuille36's Avatar
My understanding is that the car does lower itself at speeds above 68 mph, for aerodynamic reasons in the various dampening settings.
Old Feb 20, 2018 | 01:38 PM
95viper's Avatar
2007 cls550
Even in Comfort mode this is true but it will lower before that if in the sports modes. Great that we have a member here checking with a certified tech to validate.
No reason not to install the front camber bolts regardless for only $50.
Old Feb 20, 2018 | 01:56 PM
Yuille36's Avatar
I had the boys at my shop lower my 07 E63 using Star Diagnostic, but I didn't want the car slammed tearing up my CF chin spoiler. And having issues with getting over speed humps.
But I was at the shop on Friday, changing my oil and doing a complete brake job and I didn't notice any significant wear on the tires. And I running a 245/35-19 (F) and a 275/30-19 (R)
Old Feb 20, 2018 | 02:32 PM
95viper's Avatar
2007 cls550
I got 17k miles out of a set of Pilot Super Sports. Tread was nice across but inner edge burned up and split. Should have got 25k out of those. Cost me $600 to replace.
I am not lowered at all but run in Sport 2 all the time.
