E63 AMG with Long Tube Headers will cause a CEL?
w211 E63 AMG
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hey guys i have a quick question,
If i install a LTH to my 63 without getting a tune, will it cause my CEL to show?
Im planning on installing LTH Primary cats delete. but dont think i will be getting a tune right after the install.
Thank you for time
Thank you for time
W211 E55
Hi, yes you will get a cel. The first O2 sensor reads for the air/fuel ratio and the second O2 sensor reads for catalyst efficiency. If you do not code out your rear O2 sensors then you will get a cel for catalyst efficiency below threshold. I would wait for your tune. It will run a closed loop for air/fuel and cause poor gas mileage. Do them at the same time or tune first. I don't think O2 sensor spacers would work either.
w211 E63 AMG
W211 E55
No problem. Once you get them installed and tune though, we will definitely need a sound clip/video! Better have a wide open throttle pull too! Haha
2007 AMG E63 Weistec S3, 2003 Porsche GT2 with 1375 rwhp
Ken, get the headers and tune from EC and all will be well. You will love the sound and the additional power. Also, while you are at it, get the headers JetHot coated and replace the motor mounts when you do the install.
Soooo, how does the jet hot coating help? And why do the motor mounts need to replaced? I'm just asking cuz I'm looking into buying new headers and a tune? Anything else you recommend?
Jet Hot coating will help prevent corrosion to the headers and help keep in some of the heat in the header. It is advisable to at least check your motor mounts when replacing the headers because they are right there and prone to go bad on these cars. When you have to replace the motor mounts it is much easier (if not possible) to do it without the headers installed.
