another twin turbo e55 amg is born at BIP
Old 05-21-2014, 01:40 PM
  #51
BlownV8's Avatar
Received 1,071 Likes on 859 Posts
E55, GLS450, GL63, GLE350
Saaaaaweeeeet?
Old 05-21-2014, 04:03 PM
  #52
blackbenzz's Avatar
haters crazy
Is the throttle cut happening at 17PSI?
Old 05-21-2014, 04:43 PM
  #53
Bramage's Avatar
F-250
On fixed pully i could cleanly go to 17.5, then cut.. Did not want to MAP clamp and was going back to clutched pulley anyway. If this is a MAP issue, I will be interested in the fix (beyond resistors / potentiometer)
Nice job Craig.. looking forward to final results.
Old 05-21-2014, 05:36 PM
  #54
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Originally Posted by BI-Performance
Right now we are having some sort of issue with throttle cut.
At What RPM? Low boost cut ,right?
Nice work on the TT build.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 05-21-2014, 08:51 PM
  #55
chawkins2001's Avatar
2006 E55 AMG
Did'nt want to leave the fellas hanging, but the cut is not at 17lbs. We are no where near that. That's all the news I got back today before other things took preference. Not to worried about it though.
We will be back at it tomorrow, hopefully with some more data for you guys.
Old 05-21-2014, 10:08 PM
  #56
305-E55's Avatar
2017 Charger Hellcat
Good luck tomorrow..
Old 05-22-2014, 06:23 PM
  #57
RedBullJnky's Avatar
you to Hate
Any news today brotha? You can text me if you want.
Old 05-22-2014, 07:59 PM
  #58
2006 E55 AMG
News is it is at 18lbs causing the tb cut and found a exhaust leak so its off the dyno now. tony is playing with the tune trying to get around it. we have not clamped the map sensor yet and don't plan on turning the boost down either.
Old 05-22-2014, 08:16 PM
  #59
320 dreamer's Avatar
2003 porsche 996 turbo
what are the numbers craig?
Old 05-23-2014, 06:41 AM
  #60
2006 E55 AMG
We are stuck at 4000rpms brotha, that's where the tb cut kicks in. Dyno shows 430rwhp, then the leak was discovered.
Never easy, is it lol.
Old 05-23-2014, 08:07 AM
  #61
DVC
DVC's Avatar
'06 E55 AMG
You're the man! It's obvious you come from the Ford side as you actually share
Old 05-23-2014, 12:06 PM
  #62
Bramage's Avatar
F-250
WTF.. over
Old 05-23-2014, 12:14 PM
  #63
2006 E55 AMG
we are back in business
Old 05-23-2014, 12:23 PM
  #64
Denroll's Avatar
'06 E55
^Details?
Old 05-23-2014, 12:33 PM
  #65
blackbenzz's Avatar
haters crazy
Called it. Glad you figured it out.
Old 05-23-2014, 12:55 PM
  #66
Former Vendor of MBWorld
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
After putting the car back on the lift, we checked what type of springs were in the waste gates. The have 15lb springs in them which is good. That told us the the boost was not reaching the waste gates, it was leaking out somewhere prior causing the pressure to spike to 18lbs+. That spike caused the throttle cut which you guys already new about.
We smoked the system, and found the leak, so that is been buttoned up right now. Hopefully we will get her back on the dyno today, and have some more preliminary numbers.
Old 05-23-2014, 01:02 PM
  #67
rockthemullet's Avatar
2005 Mercedes E55 AMG
Old 05-23-2014, 02:35 PM
  #68
305-E55's Avatar
Way to figure that out so fast,it's not easy but you guys really know what you're doing and will be making clean power in no time!!
Old 05-23-2014, 03:06 PM
  #69
you to Hate
Old 05-25-2014, 08:03 PM
  #70
cls55tt's Avatar
CLS55TT
Keep up the good work guys. Hope to see some results at the track!
Old 05-26-2014, 12:32 AM
  #71
2006 E55 AMG
We resume tuning on Tuesday, and it has it first tracking outing June 6
Old 05-26-2014, 01:31 AM
  #72
you to Hate
MIR?
Old 05-26-2014, 01:39 AM
  #73
AMGAffalterbach's Avatar
2014 BMW M235i
Videos videos videos!
Old 05-26-2014, 03:14 AM
  #74
2006 E55 AMG
Timmayfest homey, come on up so much fun!
Old 05-28-2014, 02:04 AM
  #75
2014 BMW M235i
I'm seriously considering it this summer, and very much based on cars like these if they are there. I will try!!
Quick Reply: another twin turbo e55 amg is born at BIP
