another twin turbo e55 amg is born at BIP
#101
You are probably over running that regulator. Fuel pumps typically operate / flow better when run at a lower base pressure. Typically when pumps start to see too much pressure the flow rate drops dramatically. what brand pump is that you are using? You said it dropped 15 psi once you hit boost (how I read it) what was the actual fuel pressure at idle and then when it hit boost?
Are the pumps running in series or parallel? Is the second pump activating under boost or are both running all the time? if at the same time I would recommend maybe hooking the second up to a hobbs switch at say 8 psi so you are not running so much base fuel pressure. You might also need to increase the size of the fuel return line.
I would deff consider getting an aftermarket regulator on that car to at least dial in your base FP. www.foreinnovations.com makes some awesome regulators.
#102
75psi to 60psi then pulled out of it. Aem Dual e85 320lph pumps in the stock baskets, stock e55 fuel tank setup.
#103
We changed all the plugs and gapped them down to .022, still skipping.
Ahmad, what fuel setup did you have brotha? I have two e85 320lph pumps with 1000cc injectors and the stock regulator along with a looped rail. All the fuel lines are stock.
My fuel pressure is dropping about 15psi from idle to when we mash it, and the break up starts at that point.
#104
Also have you measured pump voltage as it hits boost? This can be pretty critical too as if he voltage drops flow is also going to take a hit.
As blackbenz stated the AFR should take a bit of a dip there and could be the cause of your misfire (lean misfire)
It certainly cant hurt to put a good FPR on the car and a larger fuel return line.
If you have a log you can post up or PM me that might help zero in on the issue.
#105
ok it sounds like both pumps are running full time then. If that's the case your base FP is probably pretty darn high. The higher the pressure the worse the flow. For instance look at the data plot below. Mind you your pump is not on there but it illustrates a common idea. The Aeromotive from what I have seen is VERY close to that AEM pump you have for reference:
![](http://www.turbobuick.com/forums/attachments/ams-fuelpumpflowchart1-jpg.135059/)
I agree on putting in a good fpr and upgrading fuel lines. Some fpr will actually increase fuel pressure at a 1:1 rate with boost.
I went with dual 044 Bosch pumps. As you can see from the graph posted, it can run higher fuel pressure without as much of a drop off.
#107
I tested voltage on my CLK55 and it was constant but I'm not sure how it is on the E55 since it is factory supercharged. The whole setup on the CLK is different. External pump etc.
Agreed Bosch 044's are a solid pump choice as their flow is very consistent which is great for dialing in a car.
what is it actually hitting for AFR at that point?
#108
2003 porsche 996 turbo
craig i have a bosch 044 of you need it but recommend against running dual pumps. run a large single like a weldon 2345 or magna fuel 725. if you run dual and one pump takes a dump you will lean out drastically and kill the motor as you won't know it until its too late
#109
Update is we tested voltage at the fuel pump and it was 12.7v, at the relay it was 13.5v, so it was down at the pumps.
We then rewired with some fresh wiring, and the voltage was holding. The old wiring like beaten up for whatever reason. We ran the car again and the fuel pressure was dropping 15psi again.
Next, we will be replacing the complete sender unit today which will come with a new regulator and fuel filter. We called aem and they said I have plenty of pump and injector for what I am trying to do.
Last, we are putting in brand new coil packs this am too. Funny thing is I was making way more power when on the 50 shot and had none of these issues. Not sure why a turbo setup making less power and the same boost would surface all these problems.
The waste gates are also internal, so maybe all that air been dumped back into the exhaust is causing a ton of turbulence and back pressure coupled with the stock manifolds.
Trying to get this b###h ready for timmayfest and running out of time!!
#110
I wouldn't put much stock in the external wastegate / back-pressure theory. You would need to shove a grapefruit into your exhaust to create that kind of back pressure to cause that level of a misfire.
Thanks for the update and best of luck!
#111
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
I agree with Pewter, it's not a backpressure issue so I'd look elsewhere.
Since you're on E85, I'd throw more timing at it down low. Spool quicker and see if you're breakup is more rpm or boost related... this should help narrow it down. We've got guys running more than 15psi on stock blowers but when the power comes in is totally different
#112
Craig I may have missed it but are you using the factory ECU?
#113
Received 1,489 Likes
This place is a joke.
FWIW depending on the year the E55 has either 1 relay powering both pumps constantly or later production cars run only 1 pump constantly and the 2nd pump has another relay activated according to engine load by the ECU. Also make sure the relay contacts are not burnt.
#114
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
We have done everything mentioned above, and it did not change one thing, right at 4700rpms it starts skipping and breaking up.
Starting to get very frustrated here due to all the extra money invested with no difference. Last resort is to clamp the map sensor which will be done on Monday. If that does not solve it, well, there is not much else that can be done.
We may try routing the waste gates to the open atmosphere to see if that makes a difference too.
I am not sure if RBJ is having similar issues, but an interesting detail is that the previous customer who ran the kit ran into the same issue, and could not get around it either.
Right at 4600rpms on our Dyno Dyamics we are sitting at 498rwhp/620rwtq at 11.2 lbs. That equates to 572rwhp on a 224 Dynojet, and the power is still going up at 45* before the breakup occurs.
My car is a 06 btw.
My car is a 06 btw.
#115
My car is a 06 btw.
My car is a 06 btw.
#116
This right here tells me it's an ECU issue... two different cars, two different fuel systems/spark plugs/coils/etc and it reacts the same. I'm sure there's an employee in Germany right now that would know exactly how to fix this
#117
E55s built from June 2005 and newer have the 2nd pump triggered by the ecu. Check your door jamb vin sticker for production date XX/XX. Make sure you are not losing that second pump. Both relays for both pumps are in the rr trunk behind the quarter panel trim. Just tossing ideas out there hard to follow the whole thread from my phone.
#121
1990 300ce supercharged and intercooled
It has been a long time since I looked at one of these. But there is either a standard pressure regulator in there and or there is a spring loaded check ball that is a pressure relief. Probably the best option is to block of mechanically these so they no longer work an put a external pressure regulator in. You can tap back into the lid for a return. Kleemann use to do this with the supercharger kits. There was a stronger spring or something that you had to install for the higher pressure. I know this is a little different but worth looking into.
#122
I thought you said above you did everything listed so far. I assumed that meant you put on an FPR and increased the size of the fuel return line.
#125
