Best pulley size for daily driver E55
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Doesn't the crank pulley actually consist of 2 pulleys bolted or pressed and pinned together? The one closer to the engine drives all the accessories, and the second one only drives the S/C? There for no need to worry about overdriving your other accessories?
You should get the CM30 pump you will thank yourself.
FYI Headers should be your first power mod on a 55k. The stock ones are awful. You will gain a lot of power and sound. Not to mention your engine will run substantially cooler.
Adding a pulley on an otherwise stock e55 is just begging for more heat soak.
GL!
#32
My recommended order of mods : (1) headers, (2) s/c pulley (~ 1 -2 psi more boost), (3) cooler plugs, and (4) split cooling with a large tank (3+ gallon reservoir) if you really are going to do repeated runs...
The '010' Bosch pump has been shown to be a better pump than the Johnson CM30, but either way this is just basic maintenance....
#33
#34
They can go out sooner then that, most have and sadly many don't even know. Mine went out before 50k miles.
GL!
GL!
#36
Thank you for the advice. I've hesitated on the headers because the cars still under warranty. If something goes wrong it won't be hard to throw the stock pulley on and get it fixed without question. That being said it's just another bolt on and I would LOVE to see the gains
#37
If you do a bit of searching you will find some of the biggest gains can be had from just the headers (the stock manifolds are awful) ~ 40whp across the power band. I too am in Cali (South OC) and no issues with smog. I also think headers are a bit "safer" than other mods, as they help the engine breath better, and should reduce EGTs. If you keep your stock manifolds and increase boost, you are just asking for trouble IMHO.
That's good news. I noticed you went with benzworks headers. I plan on them doing my work and tune also. Heard good things about those guys
#38
The problem with headers is that almost none of them are true bolt-on. Most require the deletion of your primary cats. I think PLM may be the only ones that don't?
#39
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
I am little suprised about no one doing the clutch pack upgrade. Serge from benzworks did it for me back in day when he worked for MB. I have the 2007 SL55 clutch pack on my 2004 which was bad.
#40
Also, I have found the belt wrap kit is a nice add-on too (in terms of engagement and preventing slippage)...
#43
1 Post
https://www.google.com/search?q=Supe...w=1024&bih=744
#45
PLATINUM SPONSOR
Ditto!
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#48
I'm getting that awful chirp every time the S/C clutch engages. Can feel a definite jerk when the pulley slips and it's getting worse. I'm due for a service E, but I haven't found the list of items that come with a service E on my 04 E55.
I am waiting for the right time to get the belt wrap kit from Shardul and it seems that the time is getting very close to pull the trigger.
#50
