Best pulley size for daily driver E55
Hi Guys,
I drive my car regularly and want more power but want to keep the car reliable. I'm thinking of doing a pulley with a tune. What do you suggest size wise and how much hotter will the car run without cooling upgrades?
if you haven't done so yet, just replace your IC pump...$100 and 30 mins max to swap out and peace of mind for now...it will wake your car up if the pump isn't 100%.
The car only has 56K original miles on it so I think the I/C pump should be ok. I was considering the 172mm ASP pulley and dyno tune opposed to having it flashed. Thoughts?
I installed a smaller SC pulley combined with a 'tune' (transmitted to my computer, then connected to the OBDII receptacle for installation) about 3 weeks ago. I'm very pleased with the results, and the two guys who've ridden with me when I 'punched' it were AMAZED at the acceleration. Car has 49K miles on odo.
I liked the SC pulley, as that approach is easy to do, and does not increase the speed of the other belt driven components on the engine. Just increases the boost ~2PSI. I also installed the belt wrap kit, and no more 'chirp' when the SC is activated.
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
We suggest the blower pulley, belt wrap kit and B.I.P V2 Tune, and split cooling. We made 84rwhp/94rwtq, let us know how we can help brotha!
Mine was replaced at 32,050 miles... Get the Bosch "010" version installed before you waste $$$ on anything more expensive. When the IC pump fails it doesn't matter how big your crank pulley or H/E is.... you'll be getting walked by minivans.
-G
uzzle7 (09-17-2023)
2005 E55
No idea on power but all I have done is whats in my signature. No drag radials either, the car is really hard to launch, it took many runs to get it right. I managed a 1.8 60 foot on that run and everything just hooked great. What ended up working was : Put car in Dyno mode, Huge burnout, put car into raised, stalled up as high as I could, and when I left I didn't mash it right away. I just sort of eased into it at first then mashed it. I was lucky it didn't spin!
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
https://mbworld.org/forums/engine-pe...ck-dealer.html
1 Post
Yes, the newer 010 Bosch pumps are much better but I with out a doubt will run the cm30 over the Bosch
fabtech sells both with the Bosch about 30 bucks cheaper..
http://www.fabtech-performance.com/#!amg-products/c1ekn
Good deal.
I'm leaning towards doing the sc pulley, I/C pump, h/e, tune and calling it a day. Thanks for the help guys
uzzle7 (07-31-2023)
