new intercooler pump
Hey guys I have done some research and I have found a lot of info on how to to install the pump.but I just don't know if the car should be cold before removing the bleed nipple ..lats time I did it cooling(antifreeze) liquid came squirting out ? So how did you guys do it ? Thanks in advance
No need to bleed the system if you clamp the hoses close to the pump before you remove it. You can use anything from small C-clamps to a vice grip. I seriously advise that you let the engine cool overnight as you will be working under the car and hot coolant in your eye is not anyone's idea of fun. Very easy replacement with basic tools and should only take you 30 minutes.
The pump sits at the lowest point of the circuit, so the main thing is avoiding all the fluid from pouring out on your driveway. Having watched more than 1 pump replacement (3) its as simple as:
Install new pump
My changes have all been done on a hot engine, but my guy likes it hot!
Much easier on a lift.
- Clamp both hoses (in/out)
- Remove 2 screws that mount bracket to frame
- Loosen hose clamps
- Pull hoses off (pump falls to floor)
Install new pump
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Install new pump
Install new pump
Don't stress about it, if you clamp the hoses it will be fine. Don't worry about the air in the new pump. Reconnect hoses to the new pump and unclamp. Leave it for a minute or 2 to let the fluid fill all the gaps and push any small pockets of air out, then start your engine.
Take your car for a drive for a few minutes to warm up sufficiently for the new pump to start circulating the coolant. When you get back from your drive find your bleed nipple - it is located near your supercharger clutch (nipple with small rubber boot and clamp) - use a plastic hose to connect to this and route the hose to your coolant reservoir. With your engine already warmed up and running it should divert coolant from the nipple to the reservoir through the plastic hose and get rid of any unwanted air bubbles. Easy.
2004 E55 AMG; 1991 Previa
Bro that is not how my set up looks ..my resovor is on the right side ..but I did do the bleed thanks
What's going on man ..I finally replaced the pump it was so easy !!even the bleeding part I did notice a big gap of air going threw the clear hoes ..but then I let the car sit like 5 min and still saw small Lil air bubbles did you have the same problem ? Car feels faster and better response don't know if it's just me or it gave it better power
Haha yeah I feels like it gain power or something just feels grate ..but I'm still concerned about the little air bubbles that still where coming out after 5 min of my car running ..
You should / need to bleed the stock system.
If you have an aftermarket reservoir (aka split setup), you don't need to bleed as the system automatically does it...
As stated by other members, you don't need to do anything to bleed the system. It's got a small bleed hose, really thin looking one going to the reservoir.
