I hope someone can help me with this one.
Old Jun 7, 2014 | 10:23 AM
Roverron's Avatar
ML63
Here is the issue my transmission seem to go into a light limp mode every once in awhile after driving the car hard.
It seem to be stuck in gear and doesn't shift up or down.
If I stop and restart car it goes back to normal.
When this happens the car will not change from M mode to C mode or S mode.
Could this be a TCU tune related issue?
I do have an TCU tune on the car.
Old Jun 7, 2014 | 10:58 AM
cij911's Avatar
one car at a time
Have you scanned for codes ? That is the easiest way to start identifying the problem.
Old Jun 7, 2014 | 11:17 AM
ygha's Avatar
09 SL63 AMG
What TCU tune do you have on your car?
Old Jun 7, 2014 | 11:25 AM
jcjmw's Avatar
2005 E55 Wagon
Yeh, do you get a CEL? Also, check fluid level and see if any leaks.
Old Jun 7, 2014 | 11:28 AM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Sounds like you have a conductor plate failing. Should have speed sensor codes in the tcu. It's a easy DIY project and not to hard on the wallet.
Old Jun 7, 2014 | 12:41 PM
Roverron's Avatar
ML63
Will check for codes in TCU.
I guess Ill look up conductor plate DIY.
Old Jun 8, 2014 | 04:37 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
To trans check fluid, you will need a 30 dollar trans fluid dip stick tool or borrow one. Some cars can push trans fluid up the trans wire harness into the TCU control module.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
