Dead Battery, now sheering wheel controls don't work...
I accidentally left my lights on yesterday morning. After work, I came out to a dead battery. I jumped the car with my friend's truck. After about 10 minutes of driving all my features were back up and running. The car starts fine and the batteries were replaced in 2012.
Only issue is that my steering wheel controls, horn and shift buttons do not work. Basically, everything on my steering wheel is dead. Everything else in the car works.
Any ideas?
Any ideas?
07 E63 + 07 CLK63CAB
Put the car on a charger to fully top up the battery, minimum over night. A lot of issues are a result of a less than optimal battery. The car is "smart" enough to reroute power so this is where I would start.
Thanks for the idea.
2004 MERC E55
hey mike
hey mike, how you doing man? when you get it all charged, unhook the negative side of battery post for a few minutes, just remove it and put it back on. sometimes when the battery have completely died in these cars, unhooking the battery sometimes seem to "reset" everything. wont hurt anything and it will only take a few minutes. i will call you later on wednesday and see how you coming along. take care.
PLATINUM SPONSOR
Yes, sometimes a battery reset will help but you will need to reset all your window, sunroof and steering wheel once battery is un-hooked. The best way, is to find someone with STAR, read all the codes and do a reset with star.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
I guess I got lucky because I didn't have to mess with my windows or sunroof. Just the radio presets.
Al, thanks again buddy.
I seem to have resolved the issue by leaving the battery unplugged over night. Noticed 10 min lasted more than 30 second disconnect so attempted full discharge of cat electricals
