e63 engine just blew
This, but they still may charge you $8K
The fact that you have a "trusted Indy" sounds like you don't have it dealer serviced. MB will look at your history and see you don't have it dealer serviced and you may be screwed. MB does help out good customers, ex original owners that spend there money at a dealer getting it serviced. If your car hasn't been to a dealer in years and you show up asking for a hand out
I hope I'm wrong. Good luck, I hope there at least willing to do a 50/50 split on goodwill.
I hope I'm wrong. Good luck, I hope there at least willing to do a 50/50 split on goodwill.You are absolutely correct. I've worked for mercedes dealers for 10 years, and had a client with a ML63 that engine grenaded. The diamond washer that holds the cam gear to the camshaft let loose and long story short, cylinder 7 piston was almost completely sideways. The ML had 78k miles. He regularly serviced it at the dealer and every maintenance recommendation (per mercedes) was done. So mercedes first argued that it was abuse that caused the failure, the client pointed out that all maintenance was done and that he bought a AMG vehicle to drive it hard. After some back and forward mercedes ended up taking the vehicle back and gave him a $40k credit to buy another mercedes. I would say if you don't service it there then your wasting you time asking or goodwill. But I agree that it's probably the head bolt issue and that it can be saved
I had 34k on my Z06 but the warranty had expired per time not mileage. They inspected the damage and determined it was a busted valve spring which turned out to be a factory defect, brand new crate motor with no warranty. Maybe he can get that lucky, seems the car was driven easy and it's stock, who knows. Let's see what MB has to say.
I had my E55 and the E63 serviced at this dealer up to warranty on each prior to the warranty expiring. Post warranty, cutting to the indy was more for convenience, a few blocks from my house compared to 25 miles.
- Are you the orignal owner, if not what year did you aquire the car and how many miles did you accumulate of that 105,xxx?
- If you aquired the car used, did you have records of all services performed (maintenance, repairs, warranty, TSB's, etc.)?
- What dealer and independent shops worked on your car? As an FYI, I've only taken my E63 to Fletcher Jones Mercedes (Fremont) and Mercedes Exclusively (San Jose).
- What do you think was the root cause of the failure and were you surprised (given the miles accumulated)?
- Was there anything that you observed differently (even if it's slightly minor) within the last week, month, 6 months, etc. with car prior to breakdown (noises, vibrations, feedback, etc.)?
- As a current 2007 E63 owner with 48k miles (meticulously maintained), should I be super concerned? If I can get to 100k+ miles like you than I'm fine with that.
jdeastbay… Sorry to hear, as mentioned hopefully some goodwill will be done by the dealer. Keep us updated, Good Luck man!
*Bought the car 2 years old with 10k miles. All the miles where mine. A good chunk of them a riot.
*Yes warranty work done at MB and maintenance post warranty at indy who I have a long relationship with.
*Same as above
*My guess is the combination of brutal daily bumper to bumper and hard driving when I had the chance took its tool over the years. Even with proper maintenance.
*Nothing. Ran very strong up to the event.
*Not my call, but percentage wise your on the right side of the equation. These engines are not going daily. Mine had a weak link that gave out.
I ended up dumping it to a person that has the ability to bring it back to life. And what I learned along this path is if she blows under 80k miles there is a decent chance MB will work with you. Between 80-90k a gray area. Anything above 90k and your screwed, no leverage.
