Split cooling with custom, self bleeding, BMW tank. Input needed.
Old Jun 29, 2014 | 01:19 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by HeissRod
How much of a need is there to have a self-bleeding system? Once the system is filled and bled after a pump or H/E install, why would air get introduced into the system?
Quite frankly, looking at the original AMG design, I cannot see how any coolant from the engine circuit can enter the I/C circuit. There is no route to allow engine coolant to flow into the I/C circuit. Further, the internal pressure is a constant factor. That said, obviously a split system is required with a dedicated coolant tank.
Old Jun 29, 2014 | 04:17 PM
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
The stock E55 has the intercooler and engine cooling system linked together.
This allows the two system to share the same expansion tank.
The intercooler system is filled from the engine cooling system. Once filled and bled there should not be hardly any coolant coming from the engine cooling system into the intercooler system, but they are still connected together.
On some of the other cars, I see that bleed fitting on the return line is routed to the expansion tank. With that system there will always be a very small amount of engine coolant entering the intercooler system as it is replaced from the small amount bled off of that bleed line.
To say there is no way for the engine coolant to enter the intercooler system is not accurate. After all that is how the system is filled in the first place.
The question is how much of a difference splitting the system makes on the E55. I will be there is a difference, but not as much as you might think.
G
Old Jun 30, 2014 | 12:25 AM
Roverron's Avatar
ML63
Splitting also allows you to run different chemicals for you cooling needs or none at all.
Old Jun 30, 2014 | 12:00 PM
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
DING-DING-DING!
Being a Floridian, I run nothing but distilled water and a little Water Wetter to keep the pump lubed in my IC circuit.
Old Aug 18, 2014 | 11:34 PM
JoeNobody's Avatar
Mercedes
I'm going to try sealing the open air vent on the BMW brake reservoir, and then drilling and sealing a 7-15 psi vent:
http://www.ebay.com/itm/Pressure-Rel...-/161098491498
Then the brake reservoir should behave like an actual coolant reservoir.
Old Nov 19, 2019 | 09:56 PM
Donny Linton's Avatar
Mercedes e55 AMG
Pics
Originally Posted by BRH AMG
I thought some would like to see my set-up. I made my own tank, not wanting to have BMW parts or cobra parts on my car. Hope I can load these pictures.
wheres the pictures?
Old Nov 20, 2019 | 12:44 AM
  #32
MSG 55G's Avatar
Veteran: Army
2006 E55
5 years late into the conversation Donny.
