E55 was cutting 129mph in the quarter at PBIR
#76
#80
'03 E55, Range Rover Sport Supercharged, Ducati 748R
#81
Disagree. The car isn't spinning in fact it looks like it's setup will be very 60' friendly once it gets "hated by most" higher stall TC. Comes on hard at the back end just needs some help getting into the powerband.
#83
Should hit 130s next time out. Shakedown runs were just to make sure everything was working correctly with my new tcu tune. And of course i almost went into the wall on a couple runs as the boost kicked in. Im working on a harness to wire in a boost by gear system.
#84
#86
Why are you always so negative? that coment by Denroll was about the 3000 stall converter that some like and some dont. It had nothing to do with you. And you call me a loser.
#87
Bro.. Some people just aren't worth your time, this is (1) to just avoid.. Even if you posted up a 9.00 1/4 @ 145 mph w/umpteen vidz & pix on scale he'd fault you for not running 8.99
#89
Are you referring to me? If so, all I asked for was data... Guess that means I "hate" it. I said Circle D makes good converters . The person you all buy it from is just a salesman. Obviously a turbo car will have power come on higher in the rpm range and will need a higher stall to launch closer to peak torque. It's not rocket science. If you think I hate on RBJ then you don't know what you're talking about. We talk on a regular basis and I'd help him any way I can and can't wait to see his car run quicker and faster times!
#90
It's ok if you disagree, experience says otherwise. Like I said, it will be factors other than a 60ft time that will put him into the 130's.
#92
Agreed! This guy has been hating on everything I've posted since he joined this forum. Yet he has no clue of the goals I've reached or the limits I've pushed with this car. I've given away parts for free, I've driven peoples AMGs for them at the track, I've personally pick up other members from the airport and taken them to their Hotels when they vacation down here. But I'm the loser Some people only try to pull you down because they know you are above them. Im done with this guy. And on to the next level.
#93
What have you accomplished? Being a loser felon with a dumb a** Mohawk ?
You ran 10s after 2 years trying with stupid videos every single time not getting it yet when asked about vids or charts we get crickets!
You completely gutted your car at 3800 pounds so you said which by the way I bet that's what yours weighs now lol
Reality check clstt did it at over 4300 pounds
You dogged clstt for a long time yet he posted vids and charts.
So by what you are saying people should respect you because you pick them up at airports? Ya sure
Dream on pal
Dream on pal
#94
My experience tells me that if a car is hooking up fine and leaves controlled due to tempered boost at low rpm then better track prep will not have a significant impact on the 60' and MPH. My point is it didn't go 1.9 because of track prep, it just left soft and needs a converter. Agree to disagree I still expect quicker and faster times next time he has it out I think we can both agree on that.
#95
#96
Dream on pal
Dream on pal
#97
When will you realize that he has NO obligation to prove anything to you or anybody else on this forum. He built his car for himself, not for you, or anybody else on this forum. Granted everybody has the right to be curious about a build that few others would even try to attempt, but to come off in every single one of his threads like he HAS to prove everything to you and everybody else or he's just a liar and a fake just shows what type of person you really are. He should want to post the info to help the community as a whole, not to shut up a childish member who wants to find a fault in everything he does. People like you are what ruin the forums and the sense of community for everybody else.
#98
No he comes here expecting to be praised. Have you read what posted? Like he's the only one who ran 10s give me a break.
Pioneer is the guy who does it first and proves it. Only one guy has done that, clstt and he did it without being a jerk like him.
I did give props but then he started again. By your words anyone can claim anything without proof ,
#100
1990 300ce supercharged and intercooled
I could help out with a gear recognition setup if you are interested. I can get you CAN info or set up a CAN to analog or digital switch for each gear. What kind of signal would you need for the boost controller?
