82mm throttle body without adapter plate
Old Jul 6, 2014 | 05:20 PM
jcjmw's Avatar
2005 E55 Wagon
Originally Posted by Bramage
I never had the dreaded "Hiccup" and always wondered if it had anything to do with people running adapter plates. We know if it leak its an issue.
I was thinking the same awhile back. But, I am using an adapter plate and no hiccup / P0106 after the new tune. But, my understanding is that this hiccup issue is now a thing of the past as all tuners now have the solution(?).
Old Jul 6, 2014 | 05:24 PM
jcjmw's Avatar
2005 E55 Wagon
Delete, repeat post.
Old Jul 6, 2014 | 08:33 PM
Denroll's Avatar
'06 E55
Originally Posted by BRH AMG
I did mine in a similar way, machining, welding and shot peening. I found filling the voids inside increases the flow coefficient as much as 15%. More of a venturi.
You should make one for a 90mm and sell it to me
Old Jul 6, 2014 | 09:08 PM
E55Greasemonkey's Avatar
This place is a joke.
My 82mm setup, and custom y-pipe. I feel like even the stock/SL55 80mm y-pipe is a bit of a restriction as it tapers to a smaller I.D.
Attached Thumbnails 82mm throttle body without adapter plate-img_20140402_215744.jpg   82mm throttle body without adapter plate-img_20140402_221844.jpg   82mm throttle body without adapter plate-img_20140402_222543.jpg   82mm throttle body without adapter plate-img_20140402_215723.jpg   82mm throttle body without adapter plate-img_20130530_145721.jpg
Old Jul 6, 2014 | 09:20 PM
jcjmw's Avatar
2005 E55 Wagon
What size is that black metal y pipe? And, did you make it?
Old Jul 6, 2014 | 10:52 PM
Yes I cut the pieces and had it welded. Aluminum tube from frozenboost.com. 3.5" for the TB section and 3" to fit the factory air filter boots.
Old Jul 7, 2014 | 07:27 AM
  #32
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Nice piece of work. Does anybody know what cured the hiccup, or what caused it?
Old Jul 7, 2014 | 08:58 AM
  #33
kompressede's Avatar
Sold - 05' E55
This thread has brought up some interesting info. The TB is on my mod to do list, and I'm looking to do it once and do it right.
Old Jul 7, 2014 | 11:15 AM
  #34
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
I have done a lot of testing with my accelerometer and a Dashdaq XL with Zeitronics wide band 02s, I'm currently running the BBK 90 mm TB but had the MB 82 mm TB,the stock air box seemed to be ok with 82mm TB but it is definitely restrictive with 90mm ,I'm running the spectre 5 inch air boxes because the 6 inch won't fit,unless i relocate my coils ,I have an SL55 , when I run NO air filters car runs faster,disclaimer,I'm no engineer or airflow expert,I'm just stating what has worked for me on my car,and I don't recommend driving around without air filters.I have a 4 inch T on the back of the TB which then goes to the spectre filters then to stock air inlets which I believe are equal to a 3 inch opening on both sides,this T only worked for me because there is a plate on the SL you can remove that is part of the firewall and there is a lot of fine tuning so to speak so it didn't rub on hood,I don't think E55 has that plate however I think the 6 inch filters may fit under the hood of the E55.just a little info FWIW,once you go to the 90mm TB I think you need to upgrade air intake volume IMO and from the back to back runs I made changing the different intake set ups and then trying it with no air filters,I even tried a set up pulling air from where the right hood vent is with no filter,but I couldn't hear myself think it was so loud from the supercharger and no filter lol
Old Jul 7, 2014 | 11:34 AM
  #35
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
can you post pics of your setup
Old Jul 7, 2014 | 12:05 PM
  #36
blackbenzz's Avatar
haters crazy
Anybody have the 90mm BBK tuned properly on their car yet? Any documented gains over the 82mm? I'm sure this will help the bigger Weistec blowers even more
I have a MB 82mm TB plus CNC adapter welded to sc inlet if anybody is interested. You will have to add whatever intake you want to it. I can even do a package deal with the whole sc assembly lol. I have too much stuff laying around.
Old Jul 7, 2014 | 12:40 PM
  #37
CHADisBAD's Avatar
G63
Thumbs up
Originally Posted by Sir-Boost-a-Lot
Here's a few pics of a cleaner (IMO) way to install a larger throttle body. The adapter plates work great also, but this way gives up no clearance for a larger intake tube to the firewall like a plate will. You could also slice the inlet with a band saw and weld the adapter plate on if you already have it, but I'm just posting this to show another way. The aluminum I formed to the top was 7mmX16mmx120mm for those interested.
looking good S-B-A
did my old snout arrive?
Old Jul 7, 2014 | 01:32 PM
  #38
Denroll's Avatar
'06 E55
I'm running the 90mm just fine. I did have to make my own cable using a Mopar TB plug kit and my stock cable. The problem is that it's a "thicker" TB than the 82mm and there just is not much room at all by the firewall. The OEM Y-pipe barely fits, and that is with using a lot of force. That is my current bottle neck and I'm kicking around ideas to get around it. Aside from that, I haven't noticed any driveability issues that I didn't have with the 82mm.
Old Jul 7, 2014 | 01:46 PM
  #39
shardul's Avatar
Hulk is also running one from what I understand
Old Jul 7, 2014 | 02:12 PM
  #40
Denroll's Avatar
'06 E55
Yes. He's the one that provided the pinout for the cable.
Old Jul 7, 2014 | 03:11 PM
  #41
blackbenzz's Avatar
haters crazy
Any idea how much power you picked up? The Wesitec setup relocated the tb so space shouldn't be an issue
Old Jul 7, 2014 | 03:32 PM
  #42
Denroll's Avatar
'06 E55
Maybe 20hp over the 82mm. It could be more once I get the intake situation taken care of.
Old Jul 7, 2014 | 03:40 PM
  #43
blackbenzz's Avatar
haters crazy
Nice power gain! You ever consider running the intake to one side and/or relocate the TB? If I don't part my car out I'm gonna give it a try.
Old Jul 7, 2014 | 04:14 PM
  #44
Denroll's Avatar
'06 E55
That would be a cool setup.
I need to make friends with an owner of a local fab shop.
Old Jul 8, 2014 | 08:54 AM
  #45
Bramage's Avatar
F-250
Cleaning my desk last night I found a new Snout to SC gasket. Denroll, Ill save it for you!!
EDIT, there is a FAB guy down on.. oh crap, you moved. AZ has more FAB guys per-capita than anywhere else in the world
Old Jul 8, 2014 | 10:15 AM
  #46
BC928's Avatar
2006 E55, Various other German and ‘Murican
In sandy? Where?
Old Jul 8, 2014 | 10:41 AM
  #47
Bramage's Avatar
F-250
The Fab guy I have used for a couple of projects is:
Quinn
at
http://74weld.com
Old Jul 9, 2014 | 03:15 PM
  #48
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Interesting work guys. I like this thread.
Just a quick question, i read people use the S55 AMG Snout to avoid the adapter-plate welding thingy - it is bigger, right? If so, is my one from the CL55 also bigger?
Other than that, what Aluminum welding material you used? I can TIG weld Aluminium at home, but i need to know what material to use. Can anyone check with their welder? I thought about using either AlMg5 or AlSi5 - since they are universal more or less.
Old Sep 19, 2015 | 10:01 AM
  #49
macarena78's Avatar
mercedes e55 amg w211
adapter plate
Hi!! Where can i get that adaptor plate for 82mm?
Old Mar 28, 2022 | 03:08 PM
  #50
Endri55k's Avatar
Cls55
is that silicon around tb?iam try to remove mine but it looks like have silicon like yours,and it doesnt move
