Needs plugs and wires, NGK LFR7AIX?
Old Jul 13, 2014 | 03:42 PM
berti_00's Avatar
2016 Cls63s AMG
What's the difference from kv85 and r-100
Old Jul 13, 2014 | 03:52 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Damn, I just replaced my wires and had no idea about these! If I order a set will they all be the right length, as I remember from replacing my wires some are longer than others to reach the plugs at the front of the block.
Old Jul 13, 2014 | 04:58 PM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
Originally Posted by Toadster
yes, Amazon says they don't fit because they're colder than OEM, but dozens of us prove that they do work
yep, I ran my 7s for a few months before modding - no issues - they're great plugs
check my link in the parts list:
Magnecor 85240 8.5mm KV85 CN Series Ignition Cable 1997-2011 $172
note: this is the 8.5mm part, need to find the 10mm part (if you're interested)
Magnecor's KV85 Competition (8.5mm) and R-100 Racing (10mm) Ignition Cables feature Magnecor's exclusive 2.5mm high capacity Metallic Inductance EMI Suppressed conductor consisting of stainless steel wire precisely wound at 200 turns per inch over a ferrimagnetic core. The insulating jacket is made entirely of Magnecor's exclusive TC-1500-HS high strength aerospace grade silicone rubber, and its single layer construction will prolong the jacket's insulating ability by conducting extreme heat away from hot-spots that occur near over-the-limit heat sources.
The KV85 8.5mm jacket has a service heat resistance of 600 degrees F (320 degrees C) and up to 1,000 degrees F (540 degrees C) for short burst 3 minutes. The R-100 10mm jacket has a service heat resistance of 700 degrees F (380 degrees C) and up to 1,200 degrees F (650 degrees C) for short burst 3 minutes. Even if limits are exceeded, the silicone rubber will retain its insulating ability until wires are removed from engine.
it seems the 10mm is just more insulation, not more core
where do I get the 10mm then ?
Old Jul 14, 2014 | 03:00 AM
Toadster's Avatar
2005 E55 AMG
checking their catalog, it seems only 8.5mm available for the M113 engine
http://www.magnecor.com/magnecor1/files/catalog.pdf
KV85
Year Application 8mm 7mm 8.5mm
2011-1997 4.3, 5.0, 5.4 (M113) V8 80240 87240 85240
Old Jul 14, 2014 | 07:53 AM
berti_00's Avatar
2016 Cls63s AMG
So they don't sell the 10mm anymore
Old Jul 14, 2014 | 10:05 AM
Toadster's Avatar
2005 E55 AMG
it's just 1.5mm of temperature control and bling... oh wait, you want the bling
Old Jul 15, 2014 | 02:17 AM
  #32
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
They do, brother. Call them direct and they will make them for you. On a side note, request all wires to made an inch longer. Trust me.....I have bought 6 sets of wires from them for various m113 and m113k motors I have owned.
Old Jul 15, 2014 | 02:21 AM
  #33
EREBUS's Avatar
KV85
They make custom wires for any make or model. In fact, they said they make many of the wires after the order?
Old Jul 15, 2014 | 08:52 AM
  #34
berti_00's Avatar
2016 Cls63s AMG
okay thats cool, so all the same length?? i thought some of ours were shorter than others etc no??
Old Jul 15, 2014 | 01:08 PM
  #35
EREBUS's Avatar
They are different lengths. Tell them to add an inch to their spec length.
Old Jul 30, 2014 | 01:28 PM
  #36
Got the LFR7AIX plugs and the magnacore wires and my dealer said the wires are too short. What's the issue? I got the correct part number, anyone else have this issue?
Old Jul 30, 2014 | 01:31 PM
  #37
SPatykAMG's Avatar
W211 E55
I would hope this is not the case but they not realize that they are not all the same length. They come labeled where they go.
Old Jul 30, 2014 | 10:28 PM
  #38
EREBUS's Avatar
Bro, I posted that on this thread. lol
Send them back, they will refund the money or get you longer ones. They are cool to deal with.
Old Jul 31, 2014 | 12:14 AM
  #39
How do they send me longer ones? Same part number or a different application? What plugs did you use? Since the ngk plugs are longer, does that mean the wires will fit better
Old Aug 1, 2014 | 05:52 PM
  #40
EREBUS's Avatar
You tell Magnecor to make their application size for the m113/m113k engine one inch longer on all the wires. I'm using NGK plugs.
Old Aug 3, 2014 | 02:00 AM
  #41
It ended up fitting good, huge improvement with the complete package. Ngk with magnecor
Old Aug 3, 2014 | 09:40 AM
  #42
cij911's Avatar
one car at a time
Amazing that folks replace ignition wires without testing resistance...kind of like burning old $100 bills because you like the looks of a new one....
Old Aug 3, 2014 | 01:52 PM
  #43
Worth the wait's Avatar
2006 E55
Yeah modding cars is never like burning money...lol.
Old Aug 3, 2014 | 02:50 PM
  #44
cij911's Avatar
one car at a time
Well if done properly modding can make a car better (more enjoyable, faster, etc.)...Replacing a part with an inferior part or replacing a part that is perfectly fine with an equally fine part, due to ignorance, is well, foolish....
When replacing spark plug wires, one should be testing resistance to determine whether they need replacement....
Old Aug 3, 2014 | 11:33 PM
  #45
EREBUS's Avatar
magnecor is on more racing applications than bosch. do you even want to compare the difference between high performance race spec and oem bosch? talk sh*t somewhere else
Old Aug 4, 2014 | 02:23 AM
  #46
cm60k's Avatar
Fully Agree,
racing wires got a different spec. than stock, differ material+thickness+heat resistance,,
long time of using them & still brilliant is good sign of evidence..
what kind of comparison we can dig about..
ZAYED,,
Old Aug 4, 2014 | 08:42 AM
  #47
cij911's Avatar
one car at a time
I never said Magnecor wires were no good....rather many people seem to believe the factory wires need to be replaced when in fact they may be perfectly fine and one should check resistance and compare to OEM specifications. If you want to believe that the Magnecor wires are better and make your car faster, well that is fine .
Old Aug 7, 2014 | 07:17 PM
  #48
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Gents,
I found this thread doing a search for spark plug wires for my 2002 CLK 55. I like what I have read here and elsewhere about Magnecor wires. Regarding the choice between the 8.5 and 10mm options, what size are the stock wires on the M113 engine?
Old Aug 8, 2014 | 08:37 PM
  #49
EREBUS's Avatar
Originally Posted by City Rat
Gents,
8.5mm is larger than the stock wires. Bosch does not list the size of M113k......but the core on the Magnecor wires are noticeably larger than the stock Bosch
8.5mm and 10mm Magnecor wires have the same size core
Old Aug 9, 2014 | 09:46 AM
  #50
City Rat's Avatar
Veteran: Army
Thanks, that is exactly what I needed. Again thanks for confirming that the core was the same size for both the 8.5 and the 10mm. The difference is that the 10mm has thicker insulation thus allowing it to withstand another 100 degrees of heat. I am going to assume that the wires on a stock M113 dont get near 600 degrees, ie that the 8.5 mm magnecor is superior in core size and insulation than stock.
