Cheap Logging Option?
Old Jul 23, 2014 | 09:10 AM
Denis_E55's Avatar
09 S63
What is the cheapest set up to log the car? I've seen some reviews with the Bluetooth plug ins, I do have the Xentry system and laptop coming in the mail, was wondering if I can do it thru that or what are my cheaper options? I have a 77fsp and would like to monitor IATs...
Old Jul 23, 2014 | 01:15 PM
jmb614's Avatar
E55 AMG
If you plan on modding I would at the least get a setup that will log AFR's as that cannot be done through OBD. Well, you can monitor the O2 sensor voltage but then you would need to convert it from lambda and the OBD2 port is too slow to give accurate real time data.
Old Jul 23, 2014 | 01:18 PM
Hulk's Avatar
A Merc
+1
but If you stay stock buy a scangauge
Old Jul 23, 2014 | 03:17 PM
kompressede's Avatar
Sold - 05' E55
Denis -
Many threads on options to log, and why are you looking for CHEAP?
Old Jul 23, 2014 | 03:34 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you do realize that the DAS system that you have will display all the engine parameter in real time without delay since the car is connected to the multiplexer. Now you cannot record them.
Below is the list. It is the most extensive i have seen.
Old Jul 23, 2014 | 05:34 PM
Denis_E55's Avatar
09 S63
Shardul, Under what menu can I find these settings at? I'll figure out way to record them.
Old Jul 23, 2014 | 05:45 PM
shardul's Avatar
ME2.8 > ACTUAL VALUES
Old Jul 23, 2014 | 06:41 PM
E55Greasemonkey's Avatar
This place is a joke.
Is there any software out there, similar to a screen capture program, that could be run in the background to record the values using STAR, as a type of movie? Never thought of it before.
EDIT:
It's called "screencasting" and I'm reading about a few free options right now.
Old Jul 23, 2014 | 09:10 PM
Denis_E55's Avatar
09 S63
CamTasia works well too, used it before. This is what I was planning on.
EDIT:
Old Jul 23, 2014 | 09:13 PM
I just downloaded camstudio and it doesn't seem to be working on my WIN7 desktop, and a little pissed off about the greyware it also installed without asking. I'll try CamTasia, thanks!
Old Jul 23, 2014 | 10:40 PM
Denis_E55's Avatar
09 S63
Let me know if you get it to work! If you download torrents I like thepiratebay.se lots of apps for the free
Old Jul 24, 2014 | 09:26 AM
jmb614's Avatar
E55 AMG
If you're using Win7 Fraps should be able to do what you want.
Old Jul 24, 2014 | 09:31 AM
Denis_E55's Avatar
09 S63
Thanks! Will give this a try tonight when I get home and get a present from the FedEx person! I cant wait to finally level out my car and enable my A/C without paying the dealership!
Old Jul 24, 2014 | 10:20 AM
My laptop I'd be using for logging is XP.
