Zeitronix Logging AIT and MAP
Anyone logging these two from existing/stock sensors? If so, do you have wiring diagram details?
Trying to see if avoiding adding more sensors is practical.
Thx
Thx
I don't pull directly from those 2 sensors personally as I've added a Zeitronix MAP sensor, its pretty easy to do. I pull IAT's from the OBD2 port through the Dashdaq that ties in with the Zietronix unit.
The fewer PIDs you log from OBD2 the better. I believe I pull TPS and RPM directly from the ECU, if you need I should be able to locate the pinouts diagram I have for those, others may be able to chime in with that data as well.
Yeah, I pull RPM and TPS from ECU harness, and was just thinking that picking up AIT and MAP should be very doable there also. (thus, saving some hassle, expense, and time).
Thanks for tips and offer to help though.
Yes both can pulled, but with the iat sensor since there's no calculation from dashdaq yet(waiting on it) not worth because all it will show is voltage. The map can be used as one of your user inputs, C3 10 Red/Gray , from my notes if I remember correctly and there's a calculation you will have to add into the dashdaq that's posted on the forum somewhere, but like jmb said much easier buying the boost sensor from zeitronix and tapping the surge tank.
Wow! You guys are FAST--thx for lighting responses.
Since DashDaq's are apparently out of production (and impossible to find) I am trying to do it all with ZT2. Plus the OBDII stuff is sooooo slow, it's near worthless for logging if you ask it for more then 2 data-streams.
I'd assume the Zeitronix software will read it, but can't recall if you can make any scaling calcs with it since it's just looking for 1-5V, I think.
Since stock MAP and AIT are already there, and the tune is based upon what they are actually reading, seems like a good plan unless the Z software won't report it correctly.
Is there more to consider?
I don't think the z SW will make the calculations like the dashdaq, so get the boost sensor , not that expensive if you shop around. I don't know if the dashdaq is not manufactured anymore but I just sent mine in to get repaired so at least they still support it lol
Apparently, they are coming out with some "N-Dash" thing that is supposed to be new and improved.
The cost of the sensor isn't the issue as much as just trying not cut/hack much. May have to anyway.
Is there enough material in those surge tanks to tap it, or does a bung need to be welded in?
Thx
Thx
I was looking at Zeitronix website last week, because in the past they offered a package deal with the Dashdaq. I have to wait to see what they come out with now?
And I'm all set with another bung on my headers which I hope to use soon?
IMO , the AEM that logs boost and afr with failsafe (30-4900) is a good one for 300$ , uses no obd or the dashdaq with zt2 but costs more
The reason for the zt2 is because you can log real time on rpm,tps,boost and not have to go through the obd , the difference between the obd and zt2 is easily seen on logs.
The scaling is different on the IAT, I advise adding the aftermarket sensor. The scaling is different because the resolution on the aftermarket sensor is so much greater
https://mbworld.org/forums/w211-amg/...nge-specs.html
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Two additional important parameters that can be logged is Fuel Pressure and injector Duty Cycle. For Duty Cycle I had to add Innovate SSI-4 to DashDaq.
BTW, I have a DashDaq for sale, if anyone is interested. $300 including shipping to CONUS. 9 out of 10 condition. Includes OBD2 cable. Does not include Zeitronix cable and Zeitronix license.
I am thinking of adding a second ZT map sensor to the other surge tank, a second EGT, as well as a fuel pressure sensor and second AFR off of another ZT2. Would be helpful to monitor both banks.
