Frankenstein. (motor build)
Old Feb 4, 2015 | 02:03 PM
  #101
BC928's Avatar
2006 E55, Various other German and ‘Murican
Yes. Do you inject water when using e85?
Old Feb 4, 2015 | 03:04 PM
  #102
rockthemullet's Avatar
2005 Mercedes E55 AMG
Yes, for IATs only really. I added 10% meth to the mix not too log ago as I was getting a little bit of a bog between shifts on long highway pulls and figured it was just a little too much water.
Old Feb 4, 2015 | 04:01 PM
  #103
BC928's Avatar
It quenches the spark a bit. Did the iat log change with the meth at all? Small change I would guess.
Old Feb 5, 2015 | 09:35 AM
  #104
It quenches the spark a bit. Did the iat log change with the meth at all? Small change u guess.
With the 10%? No change
Old Feb 9, 2015 | 04:05 PM
  #105
Moved
Old Oct 31, 2015 | 02:05 PM
  #106
JUNEBLOOD's Avatar
00 cl500 turbo 03 e500turbo w203_63 w203 m271sc/turbo
is the m113 and the
M113k piston the same size ? I heard that the crank in the only difference mening the stroke is larger in the m113k
Old Oct 31, 2015 | 06:12 PM
  #107
Max.H's Avatar
E55
Did it work? Higher compression? Piston to valve clearance, piston to deck? All ok? More torque faster revs what was the outcome?
Old Nov 1, 2015 | 08:09 PM
  #108
Originally Posted by JUNEBLOOD
is the m113 and the
The bore is the same between the M113 5.0/5.4 and M113k 5.4, yes. The location of the wrist pin, the skirting depth, and the rod length is different between the 5.0 and 5.4, so it would be difficult to mix and match. You can (and I have), used N/A 5.4 pistons with S/C 5.4 rods.
Yes, it worked 10.5:1 compression. Piston to valve is intact, piston to deck is stock N/A M113. More power across the board, part throttle, full throttle, 2k rpm, 6k rpm, everywhere. I melted the cylinder wall running crazy timing and shifting into 5th on a top speed run but it was all due to the timing... turned the timing down and the next motor has been running great.
Old Nov 1, 2015 | 08:16 PM
  #109
First Frankenstein motor:
M113k rods, M113k rod bearings, M113k valve springs/retainers
M113 block, M113 crank, M113 pistons/rings, M113 heads/valves/cams
Hybrid oil pump (SL500/E55), E55 oil pan, modified E55 windage tray, ARP rod bolts/head studs
On the second motor I just changed out the M113 heads for ported M113k heads and E55 cams.. everything else is the same. I have Kleemann cams sitting on the shelf I may toy with but I want to change more of the fuel system before I bother.
Old Nov 2, 2015 | 05:12 AM
  #110
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Glad it worked out, that was a bold project.
Old Apr 18, 2017 | 01:42 AM
  #111
JUNEBLOOD's Avatar
How much did u Dyno and do u have a ## or email that I can reach u at
Old Nov 18, 2018 | 04:16 AM
  #112
ctravis595's Avatar
2002 CL500 to CL55 conversion
Agreed on all points! Imagine the people purchasing these cars brand new... what if they gave their nanny the keys to go pick up the kids and she accidentally loaded it with 87 octane? These motors are not cheap to repair/replace at dealer prices, best thing to do is prevent it if at all possible. When I had everything apart I really should've measured the bowls, piston tops, piston pin location, etc to get a definitive answer on the compression.. buuut I'm fine with a ballpark figure
My hands and the significant other would prefer a longer process but that's just not how I work, haha. It's already taken too long, IMO. I've got the engine back in, trans/converter hooked up, starter, pass. header, plugs/wires, trans cooler lines, alternator, and most of the datalog wiring done. Tonight I'm shooting for driver header, all the under engine wiring, plugs/wires, rebuilt ps pump (should've taken pics when it was apart, I've got an extra if you guys want to see), and belts. I'd really like to get it running this weekend and get datalogs back to Tony at BIP.
sorry to revive an old (but great) thread. But what was the reason for rebuilding the steering pump? Is this normal on a high power build?
Old Apr 10, 2020 | 09:58 AM
  #113
Stan89's Avatar
Cls55
So you used e500 pump on m113 na block with m113k pans? But sump is way smaller on e500 pump and dosent reach low enough?
Old Apr 10, 2020 | 10:28 AM
  #114
Stan89's Avatar
Cls55
Oil pump.
The ML55 oil pump has one set of internal gears, a solid sprocket, an M113 oil to engine outlet, and a front sump pickup. The body and pickup is too tall for the E55 oil pan. The E55 oil pump has three sets of internal gears, an identical solid sprocket, an M113k oil to engine outlet, and twin front/rear sump pickups.
Attachment 376114
Attachment 376115
Since the E55 oil pump has a different outlet, I couldn't just add the E55 pump to the M113 block.
Attachment 376116
The solution, after a TON of research, was a modded oil pump originally for a SL500. This oil pump has the M113 oil to engine outlet and a similar sump system to the original E55, but with a larger sprocket.
Attachment 376117
Attachment 376118
Attachment 376119
If you notice, the rear sump tube system has attachment brackets to the main fasteners... but on the ML55 these were standard fasteners. I pulled the fasteners in those locations out of the E55 and they're shown below. Had new OEM fasteners overnighted from Ahmad (I'm tellin you, this guy is good), and installed them on the M113 block. You can see the finished product with the bracket fasteners installed further down the post.
Attachment 376120
I disassembled both pumps and originally wanted to use just the front casting out of the SL500, with the rest of the pump coming from the E55 pump. Unfortunately, these gear set bodies were just BARELY incompatible. Ended up with a full SL500 oil pump with the E55 solid sprocket up front.
Attachment 376121
Attachment 376122
Upper and lower oil pans went on. I didn't take pictures of the windage tray, but some modification of the windage tray was required to fit the slightly different rear sump tube system.
Attachment 376123
Old Apr 10, 2020 | 04:17 PM
  #115
Surprised I noticed the email notification.. I'm never on here anymore.
It was an SL500 pump... Stated three different times in the post you quoted.
Old Apr 10, 2020 | 07:24 PM
  #116
ctravis595's Avatar
I’m interested again in this thread, I just put a big turbo on my cl55 n/a swap . I heard one of the weak points of the n/a m113 engines were not just the rods but also the rings
Old Apr 10, 2020 | 07:29 PM
  #117
Rings are fine.. RingLANDS are susceptible to bad tuning.
Old Apr 10, 2020 | 07:46 PM
  #118
Stan89's Avatar
Cls55
i know but its the same pump but it dosent matter.
what you did with yours? Its still way smaller and dosent reach the bottom of pan
Old Apr 10, 2020 | 08:14 PM
  #119
I used the M113k gear drive, effectively spinning it faster than original. The pickup doesn't need to reach the bottom of the pan as long as the end is submersed in oil when in use... I may have lost 0.5 quarts of capacity with a stagnant level of oil at the bottom of the sump. On a system that holds 9.5 quarts (to my memory... I haven't had this car in years), I didn't care too much.
So where are you going with this? What's your concern here? I built the car and it ran for years before I sold it... no loss in oil pressure.
Old Apr 10, 2020 | 08:19 PM
  #120
I've turned off email notifications. If you guys want to talk about M113k tech, and the moves that I made when I had one, you're welcome to join my Facebook group. Search for AMG Enthusiasts Page, it's the one with 9k+ members
Signing off
Old Feb 24, 2021 | 08:16 PM
  #121
ChrisVannoy's Avatar
2002 Cl500
Signing off
I can’t find your page on Facebook 😞
Old Feb 24, 2021 | 08:19 PM
  #122
BC928's Avatar
Some special people have this gentleman’s number. But we also understand the color of money (because so much was spent on a dead-end platform, lol) and will not release it under one BTC.
Old Feb 24, 2021 | 08:48 PM
  #123
2002 Cl500
I don’t speak short hand (BTC?) sorry my imagination goes crazy with abbreviations I found it anyhow thank you 😊
Old Jun 7, 2021 | 12:33 PM
  #124
AMGMANIAC's Avatar
E55
I've read this thread with great interest after destroying my M113k block.
I have a donor M113 from an ML55 and from what I can gather the only part I need to obtain would be an R230 SL500oil pump which would need some modification.
Could anyone tell me if that is correct please?
Old Jun 7, 2021 | 12:50 PM
  #125
2002 Cl500
what are you trying to do?
