2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
One time use Crank Pulley Tool
Considering the cost of a Crank Pulley Removal Tool this method worked wonders. Obviously only appropriate if your current pulley/harmonic balancer is due for the bin.
I probably should mention to make sure both batteries have been disconnected prior to welding anything directly connected to the motor!
The method called for a torsion wrench being wielded in one hand with the "pulley bar" in the other. With some deft hand movements she was off within a minute!
