Airmatic valve block. How does it work?
Old Aug 20, 2014 | 10:13 PM
cwmateiuc's Avatar
2006 E55 AMG
Okay so I am having issues with my airmatic on my E55.
No leaks anywhere. I literally checked every line, fitting, tank, bag.
So I disconnected all the lines from the valve block except for the one from the compressor.
It seems that at least three valves are open at once, is this normal? Does that block control exactly where the air goes or is that dictated by a valve opening on the bag itself?
Old Aug 22, 2014 | 08:20 PM
cwmateiuc's Avatar
2006 E55 AMG
Does anyone know what the wires should be going into the unit? For some reason one wire on mine seems to do nothing.. It's not a ground and its not a positive.
I have tested during it trying to operate, also.
I can't seem to find a wiring diagram either.
Old Aug 22, 2014 | 08:51 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
Old Aug 22, 2014 | 08:58 PM
cwmateiuc's Avatar
2006 E55 AMG
Thank you!
Guess the valve block is bad. Whenever I disconnect that wire that seems to do nothing the car sees it and throws a code right away for a short. I guess the wiring is fine and the part is bad.
Just don't understand how it always works when I test it out of the car and blow in it.
Old Aug 22, 2014 | 10:23 PM
OZZYAMG's Avatar
03 W211 E55
Hi
Yes thanks also from Australia for that diagram.
Regards,
OZZYAMG
