SLS wheels on e55 ? wheel gurus come in
Hi,
anyone wheel gurus know if we are able to fit stock sls wheels 20"/19" on our w211 E55 ?
thank !
thank !
2304015302 - FRONT 19*9.5
1974010002 - FRONT 19*9.5 Offset ET60
1974011002 - FRONT 19*9.5 Offset ET60
1974010202 - FRONT 19*9.5 Offset ET59
1974010102 - REAR 20*11 Offset ET68
1974010502 - REAR 20*11 Offset ET68
1974010302 - REAR 20*11 Offset ET68
These whells will fit mechanically.
In the front with 25mm spacers ans 265/35/20
In the rear with 30mm spacers and 295/25/20 or 295/30/20.
BUT they will never fit with their load!!
The E55 has a maximum load of 1165kg (about 2570lbs) on the front axle, and 1240kg (about 2730lbs) on the rear axle.
These rims are load approved for only 565kg (1245lbs) per wheels.
so:
- in the front, you have to lighten the car for about 35kg (=80lbs) -> maybe possible
- in the rear, you have to lighten the car for about 120kg (=240kg) -> no luggage, no rear seats!!!
so:
http://www.ebay.com/itm/19-SLS-AMG-STYLE-STAGGERED-WHEELS-5X112-RIM-FITS-MERCEDES-BENZ-CL-600-2000-2006-/181476126434?pt=Motors_Car_Truck_Wheels&hash=item2a40d1eee2&vxp=mtr
basically if you're going for the style of wheels bramage posted, then there you go. If you want the wheels that come with the r231 as well as the sls, then the r231 wheels should hold better since the 231 weighs in a little more than our cars
so:
so:
Elsewise it would be possible to make passenger car rims on a Mercedes Actros truck.
I know these limitations, because I wanted to put SLS rims on my E55.
Everyone can read here: https://asp.mercedes-amg.com/certdocs
Take the German language, and you can see all certification documents to all AMG-rims.
Yes! Of course!!
