New build is underway-Weistec 3.0 and more
#176
going up![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
dyno dynamics 533rwhp; dynojet equivalent 612rwhp at 13lbs
93 pump and trunk tank for cooling only, summer e85 numbers on the old setup with meth was 532rwhp at 16.9 lbs
still working on a/f and timing....
#177
Doing it on pump gas and trunk tank no less, yeeesh
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#181
Damn Craig... this thing is a fcking BEAST. Amazing to think that you have duplicated what you had on 4lbs less of boost.
refresh my memory... are you going to run race gas for your top speed event?
#182
Just finished Chris car, he has the exact same mods as me, accept he has kleemann cams and stock rear gear. He came in at 550rwhp with 93 pump and meth. 625rwhp dynojet equivalent
#189
Great numbers , Chawkins keep up the good work , Thanks for posting the real HP #'s, I'd really like to see the HP/torgue #'s of this 5.7 liter block super builds with ported heads,, and stock block with ported heads . No body has posted any numbers from those builds yet ? . I'm considering weistec S/C up grade too , which way to go ported heads or not the real gains. Is ported heads worth the cost?
#190
'06 E55
Not cheap, but holy hell they are nice. And you will get better fuel economy while cruising. Drive long enough and they will pay for themselves
#191
Former Vendor of MBWorld
Weistec Engineering
#193
Great numbers on 93 Craig! Add some E85, nitrous, and a kill tune I can see you hitting 600 on the dyno dynamics.
Not to mention the nitrous will drop your IAT's and make an already efficient blower more efficient.. Excited to see this on the track!
#194
There's no doubt he will crack 600 with spray as long as the bottom end cooperates. Keep in mind he's still at only 13psi of boost. He can still turn it up and make more power without the spray. The pulley I sent him should be around 17+psi. He might be able to hit 600 without using nitrous
#196
well.....
You could go home alone and brag to everyone you beat your meat...
or
You could go home with a fat chick with fake boobies and take pictures?
