Rage-Tek's twin turbo E55 AMG runs 10s
#76
If you are planning on running the transmission with another computer then you are not running a 4l80e from a chevy. I provide standalone tcus for the 722.6 transmission and others and we have a tremendous amount of work making it reliable in the firmware. Shifting it is easy. Keeping it in the correct sequence and working well is not. If you are talking about creating a tq map to provide the factory tcu with the correct info then you are back to CAN integration and a lot of dyno work to provide an accurate tq map. Then receiving can data to perform your tq reduction. All doable but not a simple piggy back is all.
If you need any info I might be able to help.
#77
