intermittent starting problem
i changed 2 pump under the rear seats. and we have no codes. i also check all relay & fuse& connector & harness all in good condition. and problems is still.
we just found when the engine keep cranking, there have to voltage at the fuel pump harness. we dont know what make this situation...
finally i found a strange wiwiwiw sound under the hood when key in position 2. i dont if this relate to my starting problem.
below is video in youtube. need you guys help..
http://youtu.be/J89n5Q-efPU
ed
The whining sound sounds normal with key in position #2. Activates voltage to turn on pumps, electronics etc before crank...
but i dont have this symptoms..i have problem in cold start..
once engine is started, everthing is fine!
anyway, i ordered a new cps, i will try to change it..
ed
