Battery Control Module issues
Old Aug 26, 2014 | 06:32 PM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Well, I got the dreaded red battery light "visit workshop" message coming on intermittently. I actually changed my voltage regulator as this is usually the fix, but the message stays.
I put the car on my DAS and actually got a fault on my battery control module. The car runs and drives fine, but my voltage is at 12.6-13.1. No issue starting it and hasn't died on me yet. Before I bite the bullet and order a new control module ($360 plus shipping), is there any other related thing I could and should check that would cause a fault to the system?
Old Aug 26, 2014 | 10:13 PM
green1212's Avatar
2004 MERC E55
bcm
do you have an aftermarket audio system? does it come on when the bass is up or pounding?? if you dont have anything that is triggering it and its just seem random, then before buying the bcm, how old is the small battery up front? get that battery checked first and then move on to the trunk battery: how old is that battery? when you checked the voltage, was the car running? check these batteries with the car off and see what your voltages are: voltages on both batteries should be greater than 12.6 volts with the car off.
Old Aug 26, 2014 | 10:35 PM
WANTED!!'s Avatar
No aftermarket system.
The primary battery isn't old at all. Just under a year. The startup battery is a different story. I have no idea how old that one is.
I rechecked my voltage while driving and now it's holding steady at 13.8 while driving, which is normal. The voltage is not fluctuating wildly in either direction even when parked. However, the fault is indeed active.
I'll let it sit overnight and check again tomorrow.
Old Aug 26, 2014 | 10:39 PM
biggking's Avatar
2004 E55 AMG; 1991 Previa
BCM controllers decides when/how long to charge either battery in the AMG. I would top them both off, usually it gives errors if it detects that the batterys are not holding charge.
Old Aug 26, 2014 | 10:42 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
13.8V is not normal, 14.1 - 14.2Volts is normal. Old batteries become huge resistors and start to effect all electronics eventually.
Old Aug 26, 2014 | 10:47 PM
green1212's Avatar
2004 MERC E55
agree with above posts. the good news: the 13.8 volts that you do see is a sign that your alternator is working its butt off trying to charge and keep it all up to par. tomorrow before start up, check that front battery voltage while car is off. i would expect that maybe the cause of some of your problems.
Old Aug 27, 2014 | 02:41 AM
HARTB18C1EG6's Avatar
E55 AMG
When did you change the voltage regulator?
Old Aug 27, 2014 | 06:12 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
The front battery is for your brakes, shouldn't neglect it.
Old Aug 27, 2014 | 06:13 PM
WANTED!!'s Avatar
Yesterday before I posted this thread.
Old Aug 29, 2014 | 10:39 AM
WANTED!!'s Avatar
Well, the front battery was definitely the issue. Apparently it hadn't been changed since the car was new as it had a date of 04 on it. That, and the front post was so acid corroded that the positive lead was hanging by a thread.
Thanks for the help. I actually half forgot about that battery altogether.
