You guys are going to say "I told you so" - F14s Fail
2004 Pewter E55, 1931 Ford P/up, 1951 Ford Custom
The lugs are factory beveled but the hole only appears to have been marked at the top leading edges and not further down, properly securing the rim.
2005 E55 AMG
So I never really solved this mystery, but the MB dealership replaced all lug nuts on the remaining 3 wheels and found 5 more that were broken. Had to leave the car in the shop for 6 weeks while another wheel was being made. No issues since then.
#32
2005 E55 AMG
After the $5k repair to get a new wheel, tire, rotor, brake caliper, hub, etc. and replacing the lugs on all 4 wheels for good measure, I came out to my E55 today and found a mysterious lug on the ground. It had fallen out of the same driver's side rear wheel! I screwed it back in and then checked all other lugs. BAM...two more sheared off from the passenger side rear wheel with very little torque, like they were already broken. Now I know something's wrong with my F14 setup. I'm headed into the dealership on Friday to have them investigate. I'll see if they recommend a hub rings. I drive fast and take corners fast, but something's not right here. Lugs shouldn't break every 10,000 miles. Any other ideas?
#34
2005 E55 AMG
