*HELP ME* Power Loss- NOT IC PUMP
Old Oct 26, 2014 | 01:28 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Having a similar problem right now. IATs below ambient so pump is working. Now increase in IAT under acceleration so I'm guessing I'm not building boost. Usually when this happens the supercharger belt is off. It's fine. Clutch looks fine too. I'll log MAP tomorrow and report back.
Old Oct 26, 2014 | 08:52 PM
Logged boost. It was atmospheric pressure. Battery disconnect solved the problem. No fault codes stored.
Old Oct 26, 2014 | 09:24 PM
KleemannE55's Avatar
E55
After a little over a month or so of the power loss issue My car eventually developed a misfire/studder at 4k rpm & higher.. Plugs & #8 coil fixed my problem I'm pretty sure!
Old Oct 26, 2014 | 11:34 PM
Worth the wait's Avatar
2006 E55
Do you know when and if both fuel sender/pumps in the gas tank have been changed?
Those can cause big problems if they are not operating correctly.
Also you can call Cory@kleemann for ideas....he gives GREAT customer support!
Good luck!
Old Oct 29, 2014 | 03:12 AM
Evil E55's Avatar
2005 E55 AMG
I agree with worth the wait. Sounds like your fuel pump is starting to die on you. Just fyi our cars have two fuel pumps if one dies the car will drive fine around town but under WOT you'll start the engine (usually cylinder one) check your fuel pressure (under your air box next to cylinder one (front passenger cylinder) follow your fuel rail to the end there should be a black cap (about double the size of a tire cap) unscrew this and connect a fuel pressure gauge it should be above 3.5 bar at idol and should not drop below 3.2 bar under WOT) Hope this helps
Old Oct 29, 2014 | 11:32 AM
E55
Supposedly my car held a 10.5 AFR @ wot, have to check dyno sheet to make sure.. could the pump still be bad ?
