C63 Muffler - Install Question
Finally landed a pair of mufflers that are coming off a 2012 C63. For those who have swapped on their E55's, any tips when they arrive for the install?
I have stock headers that I may or may not swap at some point. So for now I plan to keep the primary cats and remove the resonator. With the resonator removed should I do straight pipes or an X-pipe in it's place?
Found a video on YouTube...looks like it will need a custom adaptor to move where the hanger connects. I've good a good local shop, so hopefully it won't be too bad for them.
Just need to decide what in place of the resonator. I assume most would say remove it with the new set-up.
yes depending on the shop it shouldn't be difficult. Its easily achievable with experience of tech obviously. Place X pipe were your resonators are and you'll be good.
Ok, let me see if I have this correct after some reading here. If I ONLY delete the resonator then I don't need an X-Pipe as the secondary cats have a crossover built in?
I really had not thought about deleting the secondary cats.
