Fully Adjustable Rear Camber and Toe Arms kits in Stock
#52
Just got mine from Shardul, (another +1 to him!)
Excellent quality and thanks to you beta testers and installation gurus I'll be 'gettin-er-done this weekend.
Rob
Rob
#54
Shardul,
My OEM rear lower toe arm keeps loosening up at the wheel end. Is a set available for lower rear arms only?
2007 E320 W211
Need them immediately
2007 E320 W211
#59
PLATINUM SPONSOR
Jack, when you getting the 3000 stall and suspension arms put in?
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#60
As for suspension arms, that might now have to wait. It looks like a oem bushing in my drivers side front wheel suspension needs to replaced (before I start the new suspension stuff for the rear). I texted Shardul about this.
And, very very close to the lightweight brakes project.
#61
camber arms
Would you just sell the camber arms? I have a 07 e350 sport. I bought some camber arm off ebay from a user name snoozie but its in contact with the swaybar. Im scared it will break when driving so im looking into yours Thanks
#63
They are so shiny and pretty.
Shardul, I will soon contact you about these babies! Subject to Atlanta covering the -3 against Carolina. :-)
Also, dealer told me they will accept my offer on the new e63s wagon....from 6 months ago! I told them too late (dumb asses), as I have decided to keep current wagon for another 150k miles and just mod the hell out of it!
#65
PLATINUM SPONSOR
__________________
www.ultimatepd.com
www.ultimatepd.com
#66
Getting new replacement Weistec intercooler and a dyno tune session next week. I had to replace a bushing in my front suspension arm (driver side), due to normal wear and tear. I had to replace the leaky mid headers. I got new ones from EC and installed a flex pipe to elevate stress from engine torque twisting. I will then install the meth kit. Then, the UPD suspension.
#67
Installed
Just installed mine. Very solid arms, quality products, though I wish the ends had a grease fitting to lubricate them. Maybe a future upgrade? Install was a pain in the butt only due to upper camber arm bolts are damn near impossible to remove. Aside from that, fairly straight forward and alignment changes are extremely easy now.
#69
alignment
Speaking of alignments, I don't like the factory settings of fatter tires up front, looks ridiculous. I want the same thickness on front and back, but wonder if anyone else has done the same? Which did you change, the front or the rear tires? Don't want to mess up the speedometer. thanks
#71
W211 P030 E63 AMG // W204 C63 Coupe
Any info on front kits?
I have renntech bushings in rear now, and KMACS in the front.
KMACS were all installed at same time, rear lasted 2 years and front is now 3 years and have to be changed..
Can SOMEONE please advise on a setup that isn't gonna go bad so quickly?
#72
1 Post
2000 S430, 05 E55 AMG
Replacing toe arms was a 30 minutes job start to finish per side to bad the aftermarket ones from meyle were 1/2 inch to short... Ordered adjustable ones tonight should have done that right away and saved me a bunch of *** ache and 200 at Benz for the alignment ... Hopefully adjustable ones i ordered from shardul fix my issues cause replacing 275/35/18 Bridgestone potenzas every couple thousand miles ain't fun lol
#74
I have upd rear traction arms
I bought the upd traction arms and im running an issue with the rear links beacuse i have coilovers and was wondering if you can point me to the direction for adjustable rear links
