Nitrous in Mercedes
Old 09-24-2014, 07:17 AM
Agoka's Avatar
sl55
Nitrous in Mercedes
Hello everyone. Have a 55 two pulley 180 and 84. The orifice 82. nozzle 550. manifold, intake cold. a large heat exchanger and a new pump. It has established cooling from vastatic. I want to try the nitrous...worth it or not? if Yes then which company to buy because they need reliability. If someone is nitrous please tell from installing and different difficulties.
Old 09-24-2014, 09:45 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Witgh two pulley`s your boost should be pretty high. Do you have forged pistons and built block ? Ar eyou saying you have nitorus jets in the .82 size? If so, that would be pretty large on a boosted motor.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 09-24-2014, 11:10 AM
rockthemullet's Avatar
2005 Mercedes E55 AMG
I think he's saying he has an 82mm throttle body and his injectors are 550s
To answer the OPs question, with the pulleys you're probably pushing 15-16lbs of boost and LOTS of heat. Nitrous is a great cooler, I see nothing wrong with a 25 or even a 50 shot to keep the IATs manageable
Old 09-24-2014, 11:54 AM
Hulk's Avatar
A Merc
Seems he has an 82mm tb, he can drop the timing and add some nitrous
Old 09-24-2014, 11:55 AM
Agoka's Avatar
sl55
Yes. I'm a bit incorrectly formulated. I have a 55 motor that already has...the lower pulley 180, the upper pulley 84. Throttle 82mm. the 550 injectors. a large heat exchanger and cooling from the company wastek ,tank in balancetm same exhaust with new collectors......it all goes quickly...problems with the heat..so don't feel as cooling compressor separately from the motor. Question...I want to install a nitrous Guy here who ...who has it already installed. machine with the included esp goes 12.3 402 meters, without glue
Old 09-25-2014, 09:06 AM
Craig has cooling data for his nitrous shot
https://mbworld.org/forums/w211-amg/...ml#post6168058
Old 09-25-2014, 09:35 AM
Former Vendor of MBWorld
BI-Performance's Avatar
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Yeah, OP your combo would love the sauce. I had a 188MM in my E55 and saw 16.5lbs and sprayed a 50 wet shot. Made 47rwtq and 110rwtq. Nozzles for that type of shot was a 32/18 which is a little fat on the fuel side.
Give dyno tune a call, hands down the best for setting up a nice system with plenty of features.
All you need is a programmer that has:
-window switch
-any gear lockout
-tps activated at WOT
-ramp up speed
The programmer and basic kit should be around $1000. I love mine
PM me or call if you need anymore help homey.
Craig
Old 09-25-2014, 01:37 PM
Denroll's Avatar
'06 E55
Are you in Japan?
Old 09-26-2014, 02:43 AM
Agoka's Avatar
sl55
No. I from Belarus
Quick Reply: Nitrous in Mercedes
