168mm kleemann c/p + 84mm s/c in !!!
Old 10-11-2014, 03:18 PM
sircl55amg's Avatar
2006 cls 55 amg
just installed these last night,the only mod i have is OE tune and all cat delete,+ bosch 010
went for for a couple of pull to check data this morning
AFR at WOT = 10.3 -- 10.8 ( aem wide band ) boost was = 13.5 psi peak ( elm 327 + torque app)
IAT = 49 celcius peak ( 12 celcius ambient) ( elm 327 +torque )
so next step --- the track !!!!
Old 10-11-2014, 03:20 PM
Hulk's Avatar
A Merc
Pas mal mon ami
Old 10-11-2014, 03:30 PM
sircl55amg's Avatar
2006 cls 55 amg
la poulie de pompe a eau est tres proche du c/p !!!!
Old 10-11-2014, 03:34 PM
Hulk's Avatar
A Merc
Achete une autre pulley de pompe a eau. Asp a des pulley a pompe d'eau
Old 10-11-2014, 03:54 PM
sircl55amg's Avatar
2006 cls 55 amg
parfait !!!
Old 10-12-2014, 05:18 PM
sircl55amg's Avatar
2006 cls 55 amg
it did the job !!!!
11.302 @ 122.27 mph
Old 10-12-2014, 05:21 PM
Hulk's Avatar
A Merc
Tres bon mon chum! Essaie encore
Hulk's Avatar
A Merc
La temperature aide beaucoup
Old 10-12-2014, 05:26 PM
sircl55amg's Avatar
2006 cls 55 amg
thanks !! merci a toi !!
im done for this year... i only did 2 runs... i will try to cut 11.2xx with this set up and
add a 180 c/p with smaller water pump ....
Old 10-12-2014, 05:39 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Zute all ores!
Ton auto est tres rapide...
Bravo
Old 10-12-2014, 05:47 PM
sircl55amg's Avatar
2006 cls 55 amg
merci a vous !!
thanks guys !!!
Old 10-12-2014, 05:50 PM
Hulk's Avatar
A Merc
Combien ça pèse?
Old 10-12-2014, 06:06 PM
sircl55amg's Avatar
2006 cls 55 amg
4 464 pounds + me 250lbs
Old 10-12-2014, 06:08 PM
Hulk's Avatar
A Merc
Tres proche de mon auto, 4420
Old 10-12-2014, 06:12 PM
sircl55amg's Avatar
2006 cls 55 amg
jai mi un plus petit batterie .. et enlever spare tire et floor mat...
Old 10-12-2014, 06:18 PM
Hulk's Avatar
A Merc
Braille batterie?
Old 10-12-2014, 06:31 PM
sircl55amg's Avatar
2006 cls 55 amg
non juste un plus petit.
pas braille
Old 10-12-2014, 06:37 PM
Hulk's Avatar
A Merc
J'aimerai etre a mtl pour une journé de froid haha
Old 10-12-2014, 09:42 PM
boostiality's Avatar
2004 E55
Originally Posted by sircl55amg
it did the job !!!!
11.302 @ 122.27 mph
Damn congrats bro, she is moving mighty fine
Are you planning on doing headers next? Makes you wonder if the majority of gains from headers just comes from cat-removal...
Old 10-13-2014, 08:20 AM
sircl55amg's Avatar
2006 cls 55 amg
thanks !!
no,headers in my list,the 4 x cats is the most restrictive
next mode will be 180-185 cp
Old 10-13-2014, 01:12 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I thought our car weight only 4000Lbs and if with Pano about 4100 Lbs.
So CLS55 weight very similar to E55 maybe 50Lbs different only ? wow...
Old 10-13-2014, 01:41 PM
Hulk's Avatar
A Merc
4420 is with me in it
After all that's how you drive it lol
Old 10-13-2014, 03:18 PM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Nice, the lower and upper pulley combo will give you a sevelt ratio- like just having a 180mm crank pulley.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 10-15-2014, 04:46 PM
sircl55amg's Avatar
2006 cls 55 amg
yes and very simple mod to do
no need to change water pump pulley,,,or s/c belt
Old 10-16-2014, 09:34 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
thanks !!
This has to be true.
I'm running an upper pulley only and see 13.2lbs of boost with ELM327 and torque. Your numbers (and trap speed) indicate that that the cat removal has improved flow quite a bit and lowered your boost.
How much of a bump to trap speed does the race gas give you?
Quick Reply: 168mm kleemann c/p + 84mm s/c in !!!
