R1 Concept Premier Series Rotors & Ceramic Pads Package (03-05 W211 E55 AMG)
Old Oct 19, 2014 | 07:25 PM
acuteperformance's Avatar
Former Vendor of MBWorld
R8
Hey guys,
I have got two packages for the 03-05 E55 AMG (Please PM for 06 E55 AMG packages)
R1 Premier Series - Drilled Rotors Kits with Ceramic Pads- *$998 Shipped*
Product Description :
R1 Premier Series Cross-Drilled Rotors And Ceramic Brake Pads; Front And Rear; Made with high carbon metallurgy. Black E-coat anti-corrosive coating. Guaranteed fit to OEM specifications without modification. Machined balanced and vented for cooling and performance. Cross drilled holes reduces surface temperature eliminating hot spots and warping. Chamfered holes eliminate stress fractures. Advanced long lasting brake pad formula with low dust output.
Complete high performance brake kit with OEM specs ready for installation.
Package includes 4 Brake Rotors and 8 Ceramic Brake Pads
High Carbon Metallurgy -Increases Friction and Reduces Pad Squeal
Black E-Coat Anti-Corrosive Coating to Provide Rust Protection
Mill Balanced to Reduce Feedback and Rotor Vibration
Symmetric Split Core Castings for Strength and Stability
Precision Drilled Holes for Maximum Heat Dissipation
100% Guaranteed Direct Fitment - No Modification Required
Double Disc Grinded for Smoother and Quieter Bed-in Process
365 Days Mfg's Replacement Warranty (warping or cracking)
Long Lasting Advanced Performance Brake Pad Formula with Low Dust
100% scorched to accelerate the break-in process
Shimmed to Eliminate Noise and Vibration
R1 Premier Series - Slotted Rotors Kits with Ceramic Pads- $978 Shipped
R1 Premier Series Slotted Rotors And Ceramic Brake Pads; Front And Rear; Made with high carbon metallurgy. Black E-coat anti-corrosive coating. Slots reduce stopping distance while throwing dust away from wheels. Guaranteed fit to OEM specifications without modification. Advanced long lasting brake pad formula with low dust output.
Black E-Coat Anti-Corrosive Coating to Provide Rust Protectionv
Diamond Slots - Increase Brake Pads Bite and Rotor Wear Indicator
365 Days Manufacturer's Replacement Warranty against Warping
Lifetime Replacement Warranty on Against Cracking (w/n min thk)
Old Oct 20, 2014 | 08:17 AM
moosejaw's Avatar
none
Is there a typo with that price? or is that in Pesos?
Old Oct 20, 2014 | 12:59 PM
R8
Nope! All prices are in good ol' USD
