Need help video inside
Old Oct 15, 2014 | 01:14 AM
Daarthvader's Avatar
E55 AMG
Hey everyone,
So I have a 04 e55. When I go WOT my car will not upshift in any gear, even when I click the paddles on steering wheel or shifter, in video I click it around 5 times as you can see and won't shift untill rpms drop(I never let off the throttle in the video). When I'm not a wot it drives perfectly fine has no shifting issues, anyone have any ideas?
http://youtu.be/TGRKSASm_GU
https://www.youtube.com/watch?v=TGRKSASm_GU&feature=youtu.be
(I've changed the plug that goes bad and the conductor plate)
Old Oct 16, 2014 | 02:23 PM
E55 AMG
Anyone? Any input?
Old Oct 16, 2014 | 03:26 PM
Denroll's Avatar
'06 E55
Does it do the same thing in M mode? What's with the ESP warning?
Old Oct 16, 2014 | 05:10 PM
E55 AMG
Does it in every mode, and esp came on because the delay in shift does it every time when it hangs in gear too long
Old Oct 16, 2014 | 05:53 PM
2000UZJ's Avatar
E55
ESP is throwing a code. Scan and see if there are any codes...active or pending. The car knows what's wrong.
Old Oct 16, 2014 | 10:10 PM
E55 AMG
I did with STAR only code was for the esp due to gears not changing
This is the code
Old Oct 16, 2014 | 10:12 PM
Hulk's Avatar
A Merc
Is a speed sensor code being thrown?
Old Oct 16, 2014 | 10:13 PM
E55 AMG
See previous post I just added in the code. This code only pops up on WOT. Never driving with 1/2 or even 3/4 throttle
Old Oct 16, 2014 | 10:21 PM
Hulk's Avatar
A Merc
Check your bypass valve wires, hopfully it's that
https://mbworld.org/forums/e-class-w...ong-story.html
Old Oct 16, 2014 | 10:29 PM
E55 AMG
I will check that out when I get home!
Old Oct 16, 2014 | 11:50 PM
E55 AMG
Dang, all wires are good with correct voltage
Old Oct 20, 2014 | 01:24 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Do you have a Pedal Box or Sprint Booster that may be sending bad throttle position signals? Maybe the electronics in the gas pedal itself are bad?
