HEAT EXCHANGER GROUP BUY - E55, SL55, CLS55
Old Jul 29, 2015 | 12:13 PM
  #226
AndreNY's Avatar
couple of Benzos
hopefully Soon
Old Aug 21, 2015 | 08:35 PM
  #227
Mackhack's Avatar
Do the ones who have it installed any numbers to compare stock with this one in terms of temperature differences?
Old Aug 22, 2015 | 04:50 AM
  #228
Max.H's Avatar
E55
Interested also Shardul. So, I presume no drilling required? Anyone have pics of this with E63 bumper?
Old Aug 22, 2015 | 08:41 AM
  #229
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
No drilling required. If you search online you will fimd some pictures. It will fit with the e63 front bumper
Old Aug 23, 2015 | 12:56 AM
  #230
e55joe's Avatar
2014 E63s,2004 E55, 2006 STS-V, 1969 Camaro RS/SS 396, 2012 Centennial GS Corvette
I will get one when you are ready let me know
Old Aug 23, 2015 | 01:01 AM
  #231
Mackhack's Avatar
Nobody can talk about the difference in temperature advantage?
Old Aug 31, 2015 | 11:01 AM
  #232
TraumaDude's Avatar
2019 S63, 2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
Can someone explain, with their actual numbers, the advantage of this heat exchanger?
Old Aug 31, 2015 | 11:11 AM
  #233
Mackhack's Avatar
I asked twice already. Nobody answered about the actual temperature difference they have for the IAT. If you don't know the before and after numbers, what does it do for you?
Old Aug 31, 2015 | 11:30 AM
  #234
SoCal55k's Avatar
2005 E55
Before installing it my IATs hovered around 25-30 degrees above ambient, afterwards I see 15-20 above ambient. These are crusing on the freeway numbers in 85-95 degree heat running an 80mm FSP. The only change was installing this HE. Also recovery times are drastically improved but I did not log any of that so I don't have any numbers tho throw out.
Last edited by SoCal55k; Aug 31, 2015 at 11:32 AM. Reason: Left out further explanation
Old Aug 31, 2015 | 11:52 AM
  #235
equitiesguy's Avatar
Mercedes CLS 55 AMG
There's something wrong with your car then. With stock setup on my CLS55, I'm running IAT of 10f over ambient (85f) in high Florida humidity mid-summer with the newer Bosch 010 pump installed.
I'll add for reference: Engine temp is 190-195f. and transmission sits at 175-180f.
0-80 pull at nearly full throttle sends my IAT up to 102-105, and in 30 seconds its back into 95~f range, and then a minute later 90~f (coming off STAR monitoring).
Old Aug 31, 2015 | 11:55 AM
  #236
Mackhack's Avatar
I think my pump is really broken. I read my AIT and I had 160 degrees C accelerating (not flooring it or anything) and around 140 degrees C driving around 70 mph.
Old Aug 31, 2015 | 11:59 AM
  #237
Mercedes CLS 55 AMG
It's fried. I wasn't paying attention to mine and found out it died with no warning, and no errors (and I'm not very hard on my car). Pick up the 010 Bosch from Autohaus -- $114 shipped. Make sure you have two gallons of coolant. I ended up getting way more out than I originally thought I would (though, I let it drain because I wanted to flush the coolant), and be prepared to bleed the air out of the system. Do it cold if you can so you don't crack the block.
IAT shouldn't ever be above 100f except after a pull.
Old Aug 31, 2015 | 12:08 PM
  #238
SoCal55k's Avatar
2005 E55
With a stock pulley set up mine was the same way, never more that 12 over ambient. The fixed pulley runs a lot hotter than the clutched pulleys do though.
Old Dec 27, 2017 | 11:53 AM
  #239
shardul's Avatar
Who is down for another group buy.
Price will be a lot cheaper this time around.
Old Dec 27, 2017 | 12:26 PM
  #240
Itgb's Avatar
1986 Mercedes Benz 190E 2.3-16
Interested.
Old Dec 27, 2017 | 12:37 PM
  #241
AmgSeahawker's Avatar
08 clk63, 06 E55, 05 c55, 14 ml350, 98 pathfinder. Have owned cl55, s55, cls55, c230, cl500, cls500
Also interested
Old Dec 27, 2017 | 03:52 PM
  #242
shardul's Avatar
Gets get 5 to 10 members on board to get a good pricing
Old Dec 27, 2017 | 07:20 PM
  #243
Mackhack's Avatar
Are your HEs plug and play or does it require to drill holes? What’s the price plus shipping?
Old Dec 28, 2017 | 10:01 AM
  #244
shardul's Avatar
Plug and play no drilling required.
We don't charge shipping in the USA on majority of out items.
Old Dec 28, 2017 | 08:48 PM
  #245
Mackhack's Avatar
I’ll keep reading here. Once you know you have a final price I’ll make a decision.
No drilling sounds good to me though!
Old Dec 28, 2017 | 10:22 PM
  #246
Ausiblt2006's Avatar
2006 E55 AMG
i would be in
Old Dec 29, 2017 | 05:50 PM
  #247
shardul's Avatar
Should have some numbers next week
Old Dec 29, 2017 | 07:52 PM
  #248
Mackhack's Avatar
Do you have pictures of the HE and what comes with it
Old Dec 30, 2017 | 09:54 AM
  #249
shardul's Avatar
Old Dec 30, 2017 | 03:43 PM
  #250
tw2's Avatar
tw2
I bought one from Shardul a few months ago. Very easy to install. There are some great instructions by bbirdwell and I added a couple of pointers as well from my experience but not having to drill anything or worry about the oil cooler definitely makes this a great choice.
