Larger injectors, when is the need?
Most importantly though it appears as though the stock injectors cannot handle the 500 or so RWHP from my car and this seems to correlate with the figures below.
While researching injectors I came across this handy Fuel Injector Calculator which determines suggested injector size for a specified horsepower. Aside from indicating our cars need immediate injector upgrading it seems a little overprotective to me plus I'm assuming they are actually referring to RWHP rather than flywheel? Am I reading it wrong - can someone more knowledgeable set me straight?
The calculator can be found here: http://clean.injectorrx.com/fuel-injector-calculator/
I have included a couple of screenshots from the Fuel Injector Calculator; the first is for a stock E55 at 469HP the second is my vehicle with current mods:
_________________________________
SCREENSHOT 1 @469HP (fuel-injector-calculator)
SCREENSHOT 2 @630HP (fuel-injector-calculator)
I did actually put some injector cleaner in and for what it's worth it appeared to make an immediate difference.
She's running on around 50% power I reckon with sort of surges when accelerating and revving high. Drinking more fuel also.
So if you reckon it's just the tune can I get away without upgrading the injectors yet or are they pretty much essential at this point also? Certainly that calculator to my reasoning says it is, although I know what the experts in this forum say also - what is your opinion on the calculator? It looks right and I have seen the same formula on a couple of sites, I just don't get why the injector capacities recommended should differ from what I read and know people to use?
It's not recommended to do but it's unlikely you will blow up the motor as the stock ecu has fail safes and runs rich from factory
Sorry for sounding pedantic and worried but it is my baby we're talking about!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Would love to log IDC% with the dashdaq, but I don't believe there is a PID for it.
I was on 1000cc inj for e85, and drivability suffered.
