New E55 Setup
Before the setup I had logged the following...
1) Replaced stock pump to Bosch 010 Pump (Free)
2) Replaced supercharger clutch (Free)
3) Added Split cooling ($250)
4) Will add 175MM Crank Pulley (Free)
5) Tune (Free)
Notes: I'm a daily aggressive driver (light to light)
- Does my cooling suffice? Do I necessarily need an upgraded heat exchanger? Mandatory or good to have?
- Anyone have a similar setup? Issues? Heat? Longetivity?
- Fuel injectors needed? Mandatory or good to have?
- Any tips of stuff I'm missing? Optimizations? Suggestions?
Nobody needs that... Look at my mods and mine is a daily driver.. Like you if I'm in the mood I'll race anyone/anytime.. Good luck...
Well if you want a serious answer, then yes the H/E is a common sense upgrade as well..... PM Shardul, he's running a nice group buy on the PLM-branded unit, which fits correctly and has provisions for the factory oil cooler (2005-2006 E55 models)
Recovery will be quicker, but you will still be fighting heatsoak on long pulls. You can play around with trunk tanks, KillerChillers and/or Meth as countermeasures for high IATs. Plenty of reading to do on those subjects.
Once you get your HP/TQ all beefed up, you won't have any traction.... so you should be looking at getting an LSD (Quaife) for the rear axle... and a set of good quality tires to put the power down. Shardul also sells a new toe-link kit and camber arms if you want to really fine-tune the traction side of the equation. Personally, I'm amazed at how little time and effort people spend on those items..... everyone seems to want 500+RWHP, but then confess that they run cheap Hankook tires.
The possibilities are endless, and the amount of money you can spend is also unlimited. Personally, once I get my car close to 500WHP with a good set of suspension tweaks I'm done.... that's the "sweet spot" IMHO. Chasing HP after that gets exponentially more expensive, and the reliability really starts to be a concern too.
-G
-G
