!!! ATTENTION !!!! - FUEL LEAK ISSUE HAS BEEN SETTLED BY DAIMLER-BENZ... 2014.12.23
Sadly I didn’t inspect any of this during the extended warranty period. I assumed it was resolved years back when the tank and pumps were replaced.
Not sure it will go anywhere but I filed a report with NHTSA and emailed MBUSA.
Since my car was no longer under the 15-year warranty extension per MBUSA (although the original owner had the letter and service booklet addendum nicely in with the owner’s manual pack…never getting the work done), I went ahead and just ordered the parts from my local dealer (MB Annapolis, www.getmercedesparts.com offering a 25% parts discount ordering online).
Got the two green replacement round seals, wiring pigtail for the E63, and a new sender and fuel pump unit.
Job took about two hours, taking my time. The hot tip is to attach a wire or cord to the fuel lines where they attach to the fuel pump unit. That way you can use the cord as a “fish tape” so you can pull the replacement sender unit’s hoses through the tank back to the fuel pump unit to re-attach them.
My fuel pump module (passenger side) was not leaking, so I saved it as a spare, if ever needed.
No problems since, but I am careful not to over-fill the tank when fueling up. Usually I just round it up to the nearest dollar after the first “click” of the pump handle to shut off. Don’t top off the tank when fueling up.
The parts (discounted per above) were somewhere around $600 for everything. Everything was in stock in US warehouses, so I was able to get it within just a few days. Considering getting a spare sender and pump unit again for the eventual re-leak of the unit(s) that I just replaced. Who knows how much longer MB will keep this stuff available, especially considering the relatively low numbers of E63s brought into the US…..
Don't re-use your round rubber seals where the sender module and the pump module fit into the top of the fuel tank -- order new sealing rings. They are cheap. Also, you need to check whether your car requires a "dongle" adapter for the wiring to the sender unit.
It's not too difficult of a DIY repair job. My only advice is just drive your car so that the reserve light goes in, so you have 1/8 to 1/4 of a tank of gas. Makes the job much nicer and also much safer.
Last edited by gerryvz; Dec 26, 2024 at 11:07 AM. Reason: updated on advice for additional parts to order/check.
Wanted Filter same day so bought at dealer $200 and another $46 for the Sealing Ring.
Have completed “Drive Cycles” check engine light has gone out.
If you provide me with the VIN number of your car, I can get you the part numbers you will need. You should replace both the fuel pump module and the fuel pressure module, on either side of the fuel tank. You will also need a pigtail adapter for the wiring, and two round sealing rings.
The labor takes about 60-90 minutes, and only requires a few basic hand tools. Best to be done with a half full or lower level of gas in the tank. You can siphon it out to lower the fuel level if it is high. I did the job with a nearly full tank, you just end up spilling a bit more fuel when removing the modules from the tanks.
For my 2007 E63 AMG, the parts (discounted) cost around $700 all in. There are MANY online MB dealers that offer genuine MB parts at the discount levels I mentioned above. For example, my local dealership sells MB parts online via its web site www.getmercedesparts.com
There are plenty of Youtube videos that detail how to change these modules out, as well as threads here. Save yourself 2 grand and do the job yourself. As always, be careful when working around gasoline, and do the job whilst outdoors (not in your garage) for optimum ventilation.
Does anyone know if I can get reimbursed by MBUSA for this? I know I'm out of the warranty coverage period, but seeing if anyone out there has gotten any type of reimbursement from them. Thanks
I'm also keen to learn how a software patch can mitigate a physical fuel leak on the top of a fuel delivery module. Any insight on this?
https://mbworld.org/forums/w211-amg/...formation.html
Read the whole thread; post #27 provides compatible part numbers.
Fuel pump relay schematic info for the 2003 to May 2005 W211 E55:
https://mbworld.org/forums/w211-amg/...ml#post8120332
I would have been SHOCKED if the dealership would have honored the extended warranty, past the stated 15 years from date of delivery of the vehicle. Even as a goodwill gesture.
I'm waiting for the other recent poster to detail the software update that his dealership says fixes this fuel delivery module gasoline leakage issue, though.
