Higher temps after going split coolant?? help
Old Jan 4, 2015 | 09:14 PM
trab8989's Avatar
e55, buick grand national, f250
Hey guys i just recently installed a 77mm fixed pulley. I logged my temps with the factory pulley and i was at about 20-23 degrees above ambient temp. With the 77mm pulley i was staying around 28-30 above ambient. So today i got around to installing my fabtech engine bay split cooling tank. I used distilled water and a couple bottles of water wetter. I believe i have everything correct as far as plumbing goes and i can see my pump pushing coolant back into the tank. But my iat is now around 35 degrees above ambient. All of these test were done at the same cruising speeds which was around 40mph.
Old Jan 4, 2015 | 09:44 PM
Hulk's Avatar
A Merc
Is it the same temp outside as before?
Old Jan 4, 2015 | 09:55 PM
trab8989's Avatar
Hmm it was 48 degrees when testing a bit ago. And the other day it was around 53 degrees or so.
Old Jan 4, 2015 | 10:00 PM
Hulk's Avatar
A Merc
I don't think you have to bleed it when you have the split cooling. Did you drive for the same amount of time?
Old Jan 4, 2015 | 10:08 PM
trab8989's Avatar
Well I drove for a little longer tonight to see if the temps would go down anymore.
Old Jan 4, 2015 | 10:23 PM
Hulk's Avatar
A Merc
if the engine gets hotter so will the iats, so if you tested with a cooler engine the iats will be lower
Old Jan 4, 2015 | 10:26 PM
trab8989's Avatar
hmm you may be right, the only difference that i did tonight was i let the car get all the way to operating temp and idle for a good 10 minutes before taking it out. I was trying to get the thermostat to open up and get my coolant circulating so i could put some back in that was lost in the process. I will take it out just like i did the other times and test tomorrow morning.
Old Jan 4, 2015 | 10:29 PM
XSTAR's Avatar
Two Torque Monsters...E55/Viper
After doing the split cooling mod, curious...do you need to keep a close eye on the added resavour or what do you need to look out for?
Old Jan 4, 2015 | 10:30 PM
trab8989's Avatar
I believe you just fill it like you would your radiator coolant bottle and leave it be.
Old Jan 4, 2015 | 10:36 PM
Hulk's Avatar
A Merc
Ya if the other times it wasn't at operating temps your iats will be cooler especially being in the 50s outside
Old Jan 4, 2015 | 10:38 PM
trab8989's Avatar
Well see the car was at full operating temp in all occasions. Only difference was i let the car idle for a long time to get up to operating temp in the garage tonight. Where as the other times i just started the car, let it idle maybe a minute or so then took it out and drove it until it got up to operating temp.
Old Jan 4, 2015 | 10:44 PM
Hulk's Avatar
A Merc
Yup, running idle will run higher temps but not by much and the 5* is probably it.
Old Jan 4, 2015 | 11:55 PM
trab8989's Avatar
I just took it out again, was still a little warm from before. I drove for probably a good 25 mins. As i pull out of the driveway baby'ing it the car creeps up to 120degree iat then suddenly drops very quickly. Im guessing the pump cuts on there? Temp outside was 45 degrees this time and my iat wanted to stay around 69-71 degree's. So that is about a 7-8 degree change from not being split. Would you guys say that is the normal difference from stock to split? Thanks
O car pulls like a train with the 77mm fsp... Cant make it get good traction.
Old Jan 5, 2015 | 12:11 AM
Hulk's Avatar
A Merc
You are actually pretty good considering that the fsp will keep your blower engaged
Old Jan 5, 2015 | 12:13 AM
trab8989's Avatar
Yea, summer time i might have to do a bigger heat exchanger.
Old Jan 5, 2015 | 12:32 AM
beastietd's Avatar
C32 AMG (sold) E55 AMG
I did the exact same thing, split cooling and a FTP bay tank. Initial temps show a rise in IATs.
Here in Texas it's been around 35-55 and after installing I noted my initial start up temp of 95* that was after sitting in a shop for 6-7 hours off. I've never seen this high of a start temp before. I haven't had a chance to do any more logging, but needless to say that was very concerning. I monitor via Aeroforce gauges. Subscribed for updates.
Old Jan 5, 2015 | 11:27 AM
Critter's Avatar
07 E63 + 07 CLK63CAB
FYI, for all you boys in the South, running straight water with some water wetter is not a safeguard to freezing, even at 35 degrees when first running down the road the air coming through the rad will be cooler and could freeze in your tank, just beware.
Old Jan 5, 2015 | 11:39 AM
trab8989's Avatar
Sounds like that would save me from having to put ice in the tank
Old Jan 5, 2015 | 12:21 PM
SICAMG's Avatar
2005 e55 AMG
As far as I know with my own car the pump does not turn on until lit sees a 25 percent throttle load. If I baby it the pump will stay off. I installed a led light in the dash that turns on when the pump is on so I always know when it's on or if I have a failure the light will not come on letting me know what's up. It's a great little safety "light"as far as I'm concerned.
Old Jan 5, 2015 | 12:27 PM
trab8989's Avatar
I monitored mine for about a hour last night and my pump acts differently then yours. I start the car, let it warm for a min and take off. IAT temps get all the way to 120 degrees then the pump kicks on and drops them down quickly. After that i can baby the car for probably 15 minutes or more and then the pump will kick off and get back to 120 iat and come back on. Or if i press the gas more then probably 25% the pump kicks back on immediately. Pump will not cut off if i am driving and going over 25% of the throttle.
Old Jan 5, 2015 | 12:42 PM
Hulk's Avatar
A Merc
Just wire the pump so as soon as the key is started its always on. That will help also
Old Jan 5, 2015 | 12:50 PM
2000UZJ's Avatar
E55
Do you have a link for a DIY? Mine does the same thing. IAT go up then pump kicks on.
Old Jan 5, 2015 | 01:12 PM
Hulk's Avatar
A Merc
Don't know if there's a DIY on it but run the power line from the pump to the thick brown line (iirc) on the front sam
Old Jan 5, 2015 | 03:29 PM
Critter's Avatar
Cold weather is a coming boys!!
Old Jan 5, 2015 | 04:47 PM
trab8989's Avatar
What's a front sam. Sorry if in retarded.
