Battery dead? Help...
The negative cable goes to a box with a connector on it. Are you sure it's ok to the connect that source? I was hesitant because it has that black box with a electrical connector.
To avoid risk I attached the black clamp from the trickle charger to that bolt you see. But, unsure if that's a good enough ground.. It looks ok because it connect the chassis.
Is that ok?
In a garage the vehicle is only ambient temp as you state.
A battery will fail on the coldest days and the hottest days sometimes without warning.
Personally would not risk my life or any others driving the highways here running an ancient battery,( over 5-6 years) no matter what the test outcome was. To me its like running near the wear bars on tires because they are still round and hold air. Or not changing out the brake pads until the indicator tells me. IMO Just Sayin
These cars we have are power hogs, respect that.
Just google wind chill or read the wiki which says "The effect of wind chill is to increase the rate of heat loss and reduce any warmer objects to the ambient temperature more quickly. It cannot, however, reduce the temperature of these objects below the ambient temperature, no matter how great the wind velocity."
The risk in running an ancient battery is that the car won't start. That's what it's needed for. When the car is running, you can have a dead battery and as long as the alternator is working, the car will still run.
It's says its charged green light and i suppose just mantaining it. I will leave it on another day and see what happens.
The car sat for awhile and hasn't been started often. I'm thinking the battery is going bad. I was hoping to get a little more life from maintaining the battery with the battery tender.
Above 12.7 minimum with the car off sounds too high. I think its suppose to be 12.6 and below. When car is on it should be 14.2 range. No higher
Either way I will go have it load tested and go from there. Thank you!
check your battery voltage:
put key in the ignition, turn to stop #1
push the odometer reset button 3 times, it will bring up battery voltage (mine was 11.6)
turn the key to #2 position (not start) so all accessories turn on (my voltage dropped to 11.3)
a good battery will register 12.6-12.7 on key #1 and ~12.3-12.4 on #2
I was occassionlly getting conv functions uavail and mybattery would go down to 11.6v after a while.
I just swapped my 6 yr old battery for a new one and got the battery sign with visit workshop esp warning (it wasn't red on the dash). 1 malfunction same as last time I charged the old battery.
So I shut the car off turned it on and off a couple times and no warning & no malfunction.
Did you have that as well after swapping batteries?
others may have input
About charging the AUX battery, I read somewhere that whilst charging the main battery the AUX also gets charged and once the car turns over the alternator takes care of the rest?
Is that information wrong? If the AUX was dead and the main charged wouldn't I get a msg in the cluster?
Resurrecting a dead battery is okay if you are going to use it to power a 1980 car radio for a few days, you cannot expect it to power your car without causing damage to other components.
But like you said, the easiest way to go is change the batteries and see what happens next.
