Exhaust leak crap shoot question
Old Jan 10, 2015 | 09:19 PM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
So I drove from Denver to Vegas and upon arriving I get gas and as I pull out with the window down I hear what sounds like an exhaust leak/tick. You can hear it only under part throttle acceleration and only with the window down. The funny part is the tick in not there until the car is fully warmed up. When the car is cold it's silent.
So now for the crap shoot, what is your guess on where it is from?
Old Jan 10, 2015 | 11:06 PM
Rocman8's Avatar
E55
Sometimes the factory exhaust manifolds crack. Time to get some headers!
Old Jan 11, 2015 | 07:56 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Does it sound like it might be the oil pump chain slapping the timing cover. Listen at the drivers side front wheel well.
Old Jan 11, 2015 | 08:16 AM
verminator's Avatar
2010 E63AMG
check your primary cats, mine split at the weld on the top of the can, started the same way with a little tick, also check all your mounts - engine and transmission, GL
Old Jan 11, 2015 | 12:43 PM
It is a tick that sounds just like an exhaust leak but only when the car warms up and only under acceleration. I'm thinking manifold or somewhere close to the engine.
Old Jan 11, 2015 | 03:26 PM
RikTT's Avatar
A bunch of TT's
The Oem manifold nuts do loosen up over time. But that's more of a hissing when it gets worse right around the headers. You could prob try having a look around the manifold/DP for any blackish leaks on the ex material.
Old Jan 13, 2015 | 10:24 AM
That could be a possibility. It sounds like a hissing under more throttle and a hissing tick at light throttle. I'll have to check those.
