No throttle response and bad idle after cleaning TB and painting manifold
Old Jan 14, 2015 | 10:46 AM
E55GHi5's Avatar
E55 W211
Hey
i have a big big problem.
I removed the manifolds (for painting) and the throttle body (for cleaning)
Also i changed my spark plugs.
Yesterday we put everything togehter but the car is idling very very bad.
There is also no throttle response, check engine light is on.
We checked everything if there is any air leak or somehting like that, but found nothing.
Ideas?
Patrick !
Old Jan 14, 2015 | 10:48 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
unfortunately sometimes when you clean the TB this happens.
blackbenzz's Avatar
haters crazy
Did you swap the bypass valve and TB connectors by accident?
Old Jan 14, 2015 | 10:52 AM
cm60k's Avatar
Maybe throttle need to be reset, via STAR/SDS, to let it functional (as it's fully Electronic/data)...!
ZAYED,,
Old Jan 14, 2015 | 11:00 AM
shardul's Avatar
it seems like he only removed the surge tanks not the super charger
if you don't have access to DAS search for manual TB reset procedure
Old Jan 14, 2015 | 11:51 AM
E55GHi5's Avatar
E55 W211
I´ll try the TB reset... hopefully it works!
thanks a lot for your help
Old Jan 15, 2015 | 06:33 AM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
I read that this happens often.
But as your CEL is on, i'd diagnose it with SDS asap.
