better handleing
I like your direction with the sway bar, I think Delrin bushings and your "pivot relocation" will get results, with what I think is an already too heavy bar.
in regards to steering, uping the pressure will only make your steering wheel lighter in feeling.
we do not have steering racks with adjustable ratio's like some of these newer cars have.
almost any car can be made to handle better...the question is how much are you willing to spend to do so. most race prepped road race cars have fully custom suspension down to the arms and possibly arm/suspension attachment points. in some series they are allowed to move shock towers and steering rack locations a approved amount from OEM.
Now for that loss of camber,I also put back in and then some to combat the negitive aspect of the caster removal.
To me the responce is so much faster its like driving a completely different car,still stable at high speed,quicker to navigate for say an autocross event and much more of a pleasure to drive.So again for the under steer problem ...a little more camber will fix it. Also the adjustments made all around are very small but provide great feedback to the driver and thats what I am after. I am also going to swap out my 900lb springs and pop in 1,000lb springs for a little flatter turning and some k mac bushings and leave it at that.
No car can't be made to handle. It's a myth that just because its a four door Benz it needs to handle bad but be prepared to spend alot of money. That's why no one does custom work because they don't think it's worth it. Shell out $100k and drop the weight down to ~1550kg with carbon everywhere and lightweight customs parts and you'll handle alright
...who's gonna do it though haha. Honestly if I was a billionaire or even a 50+ millionaire I would actually do that :P Would have an insane E55 haha.
I would agree with you but in this instance I think you are wrong.
These cars run upto 12degrees of castor stock. An e60 m5 runs about 5-7degrees of castor.
The fact is I did this mod and probably dialed out upto 3.5 to 4 degrees of castor with this an the bottom bolts moving the wheel back therefore decreasing castor.
Its a night and day difference! These cars simply dont turn in right with the stock wheel alignment end of story! Same tight touge like road I went down before plowing into corners could be taken at speed and with confidence it wouldnt plow as long as you didnt get silly.
I highly suggest you try it before being such an armchair critic.
It has surprised me a bit nobody makes swaybar upgrades for this car. As with the airmatic its probably the only cheap way to flatten the car out more in the corners.
I honestly dont think the airmatic is as bad as some make out on here but then I do have the Arnott upgrades so maybe its just me.
As far as the ball joint mod ....do it!! The car is completely different and I love it. I am at 2.1 degrees of camber and she seems to love it. The roads are very cold but I always test on the same turns at the same speeds and push as hard as possible so I can tell if I am going in the right direction. I have had it on my alignment rack at least 8 times messing with it!!
MJ50...looks fantastic...tires nice and planted!!!
If you retrofit lightweight rotors you will reduce the unsprung weight by almost 40 lbs. Even with the Airmatic (which I personally love for its cruising qualities) the improvement in handling is significant. Further, and assuming you have KMACS, if you lower the ride height and level the car, this also is a significant improvement. Add toe links, an LSD and you will have a car with impressive handling qualities.
Great info!
Did you do front and rear? I had a quick look at mine as I didnt have much time over the weekend and thought there wasnt alot of room to drill another hole further up but couldnt see much.... what I did notice on the front was that the link is pointing up towards the back of the car meaning drilling the front one out would work great to get it straight vertical.
I was actually thinking im going to have to take them off and squish the ends down more in a press to give me more flat meat to drill though......
This sounds great iv been happy with mine it doesnt even roll much when you push it though corners if this flattens it out more then I might have to go find some m5's at the local track days......
Reducing the caster will make it feel more nimble and have quicker steering inputs but will increase understeer and be slower through the corners.
Increase the front tire size by probably 20mm and leave the rear the same will help the understeer along with dialing in more camber in the front.
I am talking from an sl600 however they do have similar issues in regards to handing. Built in understeer, insufficient brakes and a lot of caster.
F1BHP...I know that there are some trade offs with the slight increase in under steer but the inputs back to me at the steering wheel make the car soooo much easyer to drive in EVERY condition I throw at it. Like I said when I first drove my car right off the trailer was "this thing feels like I am driving a car with two almost flat front tires". But now just whipping into a parking space is quicker and the wheel does not fight me LOL
