Eurocharged - Claimed gains vs. Real gains
Old Feb 7, 2015 | 02:23 AM
miamiE55's Avatar
2004 e55
Originally Posted by miamiE55
Do you find the torque App accurate? I use it also, I know the horsepower and torque readings are not but is boost accurate?
I'm not obsessed with the number but more of why I had such a gap between my graph and there's.
I was asking because most of you at some point came from stock to modified I figured since you guys would have dealt with some of these problems and figured out the best options through your experiences that's all.
Old Feb 7, 2015 | 09:25 AM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
See if your dyno guy can hook you up with another dyno for a test. Your gains on pulley alone are in the ball park. Your base with tune was 370 or so. Seems low. Without tune on that dyno puts u at 345-350. All the numbers add up to be 35-40 hp low across the norm.
Old Feb 7, 2015 | 09:58 AM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
He's inline if this is an honest Dyno Dynamics.
Old Feb 7, 2015 | 12:00 PM
10-94's Avatar
09 E63 - 03 Sonic Blue Lightning - 09 F150 4x4 Beater
Did you ever get any baseline numbers? Hard to determine gains unless there is something to compare them to, preferably on the same dyno.
Old Feb 7, 2015 | 03:06 PM
RikTT's Avatar
A bunch of TT's
Who here has made 470 + whp on a Dyno Dynamics or Mustang dyno ? *NOT on a Dyno Jet*
This would be for : Pulley/Tune/Short (or LT) headers & of course IC pump/HE to support.
I'm going to leave out dyno calibration/sea height or shoot out etc. just to get a general idea across the board.
Old Feb 7, 2015 | 03:23 PM
SPatykAMG's Avatar
W211 E55
I made 500whp 600wtq on the EC Houston dyno. This is with upper and 180 lower, EC LT, tb, injectors, plus lots of cooling.
Old Feb 7, 2015 | 06:45 PM
  #32
miamiE55's Avatar
2004 e55
I forgot to mention my MPG has definitely improved !!
I dont have a true baseline because I had the tune on my first time at the dyno
Old Feb 7, 2015 | 10:01 PM
  #33
Mr. CVE's Avatar
MY06 E55
Not sure if this helps.... but I will give you some of MY experiences.
I do a lot of ecu remapping and dyno tuning here in Australia.
Almost ALL dynos read different, some up some down. So while the ACTUAL number may not be ( in your opinion ) correct, the gains or drops AS A PERCENTAGE should be pretty accurate.
There are also so many other things that affect dyno numbers, tyre compound, tyre pressure, way it is tied on the dyno , all the way down the diff oil used. and thats not vene before we go to atmospheric conditions... air quality etc.
Wherever possible I always dyno the car before and after, because just because the number is lower than what you wanted, doesn't mean it is slower.
I also run many dyno days and hear it all the time.. what did my car only make 400 ? yesterday at MrX dyno it made 450 ??
The other thing, what does the Bum-O-Meter say ? does it feel faster ?
I hope that helps a little.
If you have any questions or criticisms let me know ( politely !! ), as I am always interested in learning new things
Old Feb 8, 2015 | 06:31 AM
  #34
Toadster's Avatar
2005 E55 AMG
I made 448/487 with S/C pulley and ECU tune with FTP H/E and new Bosch 010 pump
adding Kleemanns I went to 481/519
Old Feb 8, 2015 | 09:42 AM
  #35
c55asleep?'s Avatar
Bicycle
Who's dyno did you end up going to?
Old Feb 8, 2015 | 01:33 PM
  #36
RikTT's Avatar
A bunch of TT's
Dyno type ?
I ask b/c I made 445WHP 500TQ on a Mustang Dyno w Kleemans. (Mods are in Sig)
EC live dyno tuned in cold temp
Old Feb 8, 2015 | 08:07 PM
  #37
miamiE55's Avatar
2004 e55
Wow Toadster , you see thats why Im questioning myself when I hear people like yourself with at one point had similar mods but got more gains, makes me wonder why I'm much lower.
Once again thank you guys for all the advice
I went to Garage yourself in Miami, they have a Dyno Dynamics
Old Feb 8, 2015 | 08:38 PM
  #38
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
See link in sig for tune/K&N/HE/010 pump only. Not sure what kind of dyno EC Houston uses.
Old Feb 8, 2015 | 09:53 PM
  #39
10-94's Avatar
Dyno Dynamics. I just had my car dynoed there.
Old Feb 9, 2015 | 09:06 AM
  #40
c55asleep?'s Avatar
Bicycle
I need to get mine retuned. Does he work with Jerry? (Moosejaw) had replaced the tb and it needs some refinement. Misses a little when partial gas given
Old Feb 9, 2015 | 09:27 AM
  #41
Hulk's Avatar
A Merc
Any dyno can work with Jerry if you have the cable to reflash. If you don't have that cable get it from EC
Old Feb 9, 2015 | 09:48 AM
  #42
miamiE55's Avatar
2004 e55
Hulk is right anyone can work with Jerry if you have the cable, but after the little conversation they had about dyno configurations I wouldn't suggest it hahaha
Let me know where and when you go I would like to go for another dyno session maybe ill go with you so you can give me your opinion as well in person on a dyno about my issues and do a 3rd gear pull this time
Old Feb 9, 2015 | 10:07 AM
  #43
sales@eurocharged.com's Avatar
SPONSOR
C63S
Let me know when and I'll happily donate my time.
Old Feb 9, 2015 | 10:55 AM
  #44
Hulk's Avatar
A Merc
If you can log via zt2 and dashdaq then dyno doesn't really matter because you give Jerry the log of the dyno run and he adjusts it.
I was tuned in maybe 10-15 min
Without logs, you have to send him the dyno graph and he adjusts timing, fueling etc
The cable and tune upload is a great tool to have
Old Feb 9, 2015 | 03:25 PM
  #45
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
we should have our brand new AWD top of the line dynojet in very soon!
Old Feb 9, 2015 | 08:04 PM
  #46
c55asleep?'s Avatar
Bicycle
Andrew (Moosejaw) originally had it done at ragetek with Nemo. We can set up a date with Nemo and go from there. I remember when I had to send my ECU to Jerry when I had my C55 back in 2006!
Old Feb 9, 2015 | 08:23 PM
  #47
Hulk's Avatar
A Merc
After it does that miss as you explain it does it shake or you can go from there without issue
Old Feb 9, 2015 | 09:58 PM
  #48
c55asleep?'s Avatar
Bicycle
Hulk not sure if you were referring to me, but mine hesitates a little from a dead stop then starting off. It kinda feels as if the traction control kicks on but its not. Does it even with soft throttle given. The throttle body had been changed but hasn't been retuned for it.. Again if you weren't referring to me I apologize for going off topic..
Old Feb 9, 2015 | 11:28 PM
  #49
Hulk's Avatar
A Merc
Yes it was to you, don't go wot til you retune it
Old Feb 10, 2015 | 08:50 AM
  #50
mobhouse's Avatar
Mercedes E55
I just dropped off my car yesterday to Eurocharged here in Houston. Getting headers, H/E, TCU, and Dyno Tune done. Previously had just an 84mm s/c pulley and logic lab tune. Honestly don't really recommend logic lab tunes. I put down 393/442 on a Dynocom dyno with those two mods and a good 010 pump. Aiming for at least 475/500 with Jerry's tune. I doubt he'll disappoint
