P2561, P2220A, P2562
Does anyone recognize these codes or know what they mean? Car went into limp mode back in November and haven't driven it since. Finally took it to the shop and they said it shifted fine with no issues and they cleared the code. I'm confused and still worried! Help! This is for a 2005 E55 AMG
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
https://mbworld.org/forums/w211-amg/...ml#post6328447
conductor plate
I had the conductor plate changed and so far so good. Are you also hearing the loud pitched whine when you accelerate? If so that's the tranny pump but should fix itself when the conductor plate is changed (unless it's damaged). I bought the conductor plate from Amazon for $150. They will check for metal shavings to see if there is any internal damage. Good luck man!
2005 Mercedes E55 AMG
Thanks alot... The car is at the shop now he is changing out the electric plug connector that connects to the conductor plate and than im also having the transmission oil changed with the gasket and filter ... Should i change out the conducter plate while I'm at it? What would u recommend?
