Throttle Body Plug?
Old Feb 13, 2015 | 12:54 AM
menace2sobriety's Avatar
2004 E55 AMG
Throttle Body Plug?
Hey guys,
I have started stripping my engine down to paint and do the throttle body half shaft mod
I found the plug on the throttle body but cannot seem to figure out how to remove it
There seems to be some sort of hard gasket gunk around the plug which may stop me from being able to unclip it
Am I looking at the right plug?
I don't want to break it trying to take it out - spares are scarce here to say the least
I have attached the photo of it
Old Feb 13, 2015 | 01:44 AM
2004 E55 AMG
Problem solved duuh
Found the plug down further on the loom which I thought was just "loom"
Not even drunk either
All good now
Old Feb 13, 2015 | 05:33 AM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
What is the TB half shaft mod?
Old Feb 13, 2015 | 07:47 AM
Hulk's Avatar
A Merc
Ya the stock tb on the E55 has some epoxy around the plug, unplugging it from the harness is the only way.
Old Feb 13, 2015 | 02:00 PM
2004 E55 AMG
Do a search in the forum for throttle body shaft grind, its similar to that but its the old hot rodders way of doing it where you remove the top non threaded shaft (i'll be leaving a few mm on each side for butterfly support instead of going all the way up to the throttle wall - if going right to the wall you are then reliant on the screws to keep everything together
Old Feb 13, 2015 | 03:41 PM
JoeNobody's Avatar
Mercedes
On a side note,
Does anyone have an extra throttle body harness they want to sell? I'm looking to swap my throttle body but I can't get the plug off.
Old Feb 15, 2015 | 05:36 PM
romeomikehotel's Avatar
cls55 amg
the plug is about 12" away from the throttle body on the harness... unplug it from there
Old Feb 15, 2015 | 05:52 PM
2004 E55 AMG
Thanks.
If you had read the very second post I resolved it
*** THREAD CLOSED ***
Old Feb 15, 2015 | 07:34 PM
cls55 amg
Originally Posted by menace2sobriety
Thanks.
Thanks. But I was replying to JoeNobody one post up...
