Passenger seat movement / wobbles - anyone fixed this?
Old Sep 23, 2017 | 01:09 PM
sbaer's Avatar
2011 E63 M156 :) - previously: 2016 GLE63 with U21 (missed); 2012 ML550 , ML63 2009 - E550 W212 2010
My seat actually has play above that screw. Has anyone had that issue yet?
Old Feb 12, 2020 | 05:14 PM
BC928's Avatar
2006 E55, Various other German and ‘Murican
As an update there are three (3) separate different seat attachment pin types. Looks like front two are same.
Rear two are different for onboard and outboard. Love ze Germans.
Outside has a larger longer bolt with two different plastic inserts. Did not take a pic, as I was just checking to see if it was in good shape.
Inside is somewhat different then the fronts but mostly similar except for shoulder diameter for largest diameter steps on bolt.
Pretty needlessly complex, but, you know, the Germans.
Old Aug 17, 2020 | 09:52 PM
Jbrody1072's Avatar
2005 E55 AMG
Does anyone have the part #s for the 2 different sized rear bolts as mine are bad?
Old Oct 5, 2020 | 05:18 PM
charlesb2003's Avatar
2005 E320, 2008 E320 Bluetec
+1
I need to replace all of my bolts and bushings. One of my bolts snapped while replacing a failed WSS sensor and the plastic bushing disintegrated so I want to replace all of mine just to be on the safe side. Open to more permanent solutions, preferably those made of metal.
Old Nov 29, 2020 | 12:09 AM
SilverioLuna's Avatar
W211
Wobble seat
Bushin
Part #145 is not available separately, come with #10 ($1,700.00)
I recommend go to the Hardware store and get a brass / bronze bushings I.D. 12mm, O.D 15mm cuts pieces of 5.6mm / 5.5 (only 3 ),
the 4th weight sensor don’t required bushing, as spacer between the bolt head rail any nylon washer.
Old Nov 29, 2020 | 12:16 AM
W211
Old Nov 8, 2022 | 02:09 AM
  #32
Ariwbk's Avatar
Cls w219 550
hello, could you ask for the part number of this plastic or a photo at least where is this plastic in Volvo? Thank you and best regards
Originally Posted by JohnLane
Guys I've fixed this in my two-elemon car by replacing the rotton MB rubber bushing with a plastic bushing as used by Volvo at the bottom of the shifter for Volvo's M-46 transmission. Order it up for any 200 or 700 model car with the M-46 box. Easy-peasy. Seat moves as when new.
Old Jan 13, 2023 | 07:09 AM
  #33
DuhStig's Avatar
E320 CDI
1209638
Old Nov 3, 2025 | 12:42 AM
  #34
jonUF02's Avatar
2015 GL550 4matic
Originally Posted by DuhStig
1209638
Just ordered 2 of these Volvo bushings for about $10 to repair my wobbly front passenger seat. Hopefully it's a nice fit as you say.
Old Nov 4, 2025 | 12:49 AM
  #35
tlambert's Avatar
2005 E55 AMG
Once you get it fixed post back and let us know how it worked out.
Old Nov 20, 2025 | 04:00 PM
  #36
benzspill's Avatar
2008 CLS550
Hey @jonUF02 curious if you ended up trying those Volvo bushings? I might seem to be having the same issue and thing of trying it otherwise I might just fork the money for the Mercedes part since its annoying having the seat rocking.
Old Nov 20, 2025 | 05:26 PM
  #37
jonUF02's Avatar
2015 GL550 4matic
@benzspill I did get them and I don't see how they would work. I ended up just doing the tape method and it's good enough. I'm not paying $200+ for the MB kit with a few bushings and bolts.
