Manual shifting only showing 4 gears?
Old Feb 19, 2015 | 10:21 PM
06E55BEAST's Avatar
2006 E55
When i switch it to M mode or use the paddle buttons it only shows 4 gears then goes to C mode. If im not crazy, i thought we had 5 gears?
Old Feb 19, 2015 | 10:59 PM
2000UZJ's Avatar
E55
5th gear is only usable in M mode at highway speeds (50MPH). It won't let you shift if it will drop the RPM's too low.
It's indeed a 5 speed
In "C" Mode it will allow you to manually shift gears 1-4. When you shift into "5" it reverts back to shifting automatically. You can only manually shift into 5th in "M" mode.
Hope that helps.
Old Feb 20, 2015 | 12:16 AM
bdraub's Avatar
2004 E55 AMG , Remote Control Ferrari Enzo
like 2000UZJ said, if the engine is revving at too low of rpm's the car will not have enough power i think... or however to say it and will stall out, RPM too low engine die, RPM high engine go vroom vroom
Old Feb 20, 2015 | 11:26 PM
e500slr's Avatar
2011 E63, 2013 CLS63
In M you skip 5th and go to 6th.
